4.8 N2o?
Old Mar 12, 2004 | 10:45 PM
TieRod's Avatar
Default 4.8 N2o?
How much gogas can I put to a poor little 4.8L without going
It be on it for one night. I can build a dry or wet kit so need to know what the max on both are?
Thanks!
Old Mar 14, 2004 | 09:54 AM
TieRod's Avatar
Ok no answer I'll put it this way. Ive done a 150 dry set up on a 6L before but I'm not sure if a 4.8L can handle that much or shoud do 150 wet to be on the safe side?
Dry can be easy hide but if I go wet I going to have to restrane my self not put in the 200 pills. The videos of all this sould be funny and I'll try to get them up asap but my time is very limited during the week.
Thanks!
Old Mar 14, 2004 | 10:00 AM
parish8's Avatar
single digit dreamer
i am sure you could hit it with at least a 175wet.
dont spray under 3000rpm and watch your 02's the first couple of times you hit it and put some good gas in there just for some insurance.
i ran out of fuel pump on a 6.0 with 175jets so a 150 is max on a 6.0 but with a 4.8 you might be able to go all the way to a 200shot and not run out of fuel.
Old Mar 14, 2004 | 02:44 PM
TieRod's Avatar
Thanks for the reply parish. I'll probably do 175shot and 10 gallons of 100 octane. To bad it will take a while to get videos of this done but it will be alot of fun!
Old Mar 14, 2004 | 03:08 PM
Dont be scared, run the big dry shot.
They're more fun. Mine does great 70mph burnouts, to bad it wont hook though.
Old Mar 14, 2004 | 04:42 PM
parish8's Avatar
i dont have much experience with the dry shot but i have been messing around a little, my maf doesn't seem to reconigze the nitrous like i would think. i like the wet set up much better
Old Mar 14, 2004 | 04:51 PM
GoldenVelvet's Avatar
The little 4.8 has the same size injectors as the 6.0. The 4.8 wont move as much air as the 6.0 so you do have more room left for a dry shot.
Old Mar 14, 2004 | 05:13 PM
parish8's Avatar
i wasn't talking about injectors, just the fuel pump.
i dont think the stock injectors would properly support a 100dry shot. my injectors were nearly maxed on a stock 6.0 and with a cam were at 110%
Old Mar 14, 2004 | 08:52 PM
TieRod's Avatar
I've always had problems with consistency whith dry kits. But its not going to matter much its more about racing it and acting like a fool!!!
Old Mar 14, 2004 | 11:53 PM
yes nitrous and acting like a fool go hand in hand
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
vipergtrdj
Sep 11, 2015 05:52 PM
hackrst
Sep 2, 2015 05:27 PM
