new heads or port mine?
Old Mar 14, 2004 | 12:55 PM
hdhorsepower's Avatar
Default new heads or port mine?
hey guys i just ordered a new cam 216-220 comp cam and was thinking about doing heads at the same time. would the patriot heads be worth it or who can port mine in a resonable time.ialready have the same6.0 heads that patriot uses but there heads are done and ready to go,no waiting.how much power will i pick up with the heads?
Old Mar 14, 2004 | 01:15 PM
with a cam a little extra flow goes a long was. Mill them while your at it. Milling can be done in half a day with a machine shop thats not to busy. Porting can take a little longer. My heads took a total of 18 hours for both heads. But it was worth it. I cant wait to throw a cam in and see how much more power i get. Whats the lift on that cam?
Old Mar 14, 2004 | 01:21 PM
the lift on my cam is only .520 .530 it doesnt have a whole bunch of lift.
Old Mar 14, 2004 | 01:47 PM
Thats a perfect cam for a supercharger. With that lift you can probibly keep the stock springs, but id change them to be safe. With the cam and a little head work i bet you'll dyno at over 300rwhp easy.
Old Mar 14, 2004 | 04:00 PM
greentahoe's Avatar
I know nothing about cams etc, but what else would one need to install this?? Would I lose boost, by changing the cam or having headwork done?? Do I need new springs, pushrods????
Old Mar 15, 2004 | 01:15 AM
New springs are almost a must with any cam swap. You could go with the cheaper Z06 springs and be fine. With ported heads and the cam you have you will see some awsome gains with a SC. You dont want extreme lift with boost. The Buick GNXs only had .4s on lift. You dont realy have to have push rods, but it would be a good investment. Oh, yea i didnt know you were going to run a SC when i said mill your heads. Thats not something you want to do with boost.
Hope this helps some, my knoledge is kinda limmited on this subject.
Old Mar 15, 2004 | 01:22 AM
Banned
a set of patriot heads would ROCK on your setup....not to many guys have ran heads on stock motors so it's still up in the air on how much gain there is with them...but it's worth it if you want to spend the money. Call terry at patriot and tell him you already have a set of heads and that you'll send them to him and he can do the work on those, it comes out cheaper that way. i did it....just leave the valve sizes stock (2.00/1.55)....
greedygenius
Sep 3, 2015 06:51 AM
Verz
Aug 21, 2015 06:40 PM
jmarkway
Jul 18, 2015 09:23 PM
rumblebox
Jul 15, 2015 01:08 AM
4B11T
Jul 13, 2015 03:48 PM
