4.8 to 6.0
Old Feb 9, 2007 | 01:39 AM
01 Sierra's Avatar
Default 4.8 to 6.0
I have noticed alot of people have done this swap how much does it run? i want a complete price..and do u have to remap the computer? ive always wanted to do this just never knew were to start or if i have the funds to do it...
Old Feb 9, 2007 | 01:45 AM
LesPaul's Avatar
the swap it self isn't much more than the cost of the engine if you do it yourself... yes you will need to tune the engine to run right.. nelson does a good job from what i hear and he is a sponsor to the right.... now after you get the engine in, then you have to worry about **** breaking constantly... fun stuff... the transmission is almost surly to go and you will need to put a build one in that is going to run you at least $2000, then things like the rear end goes and all that fun drivetraine stuff... but after all that is built up.. you can have fun with it......
so your looking at, around $4000 for engine and trans,,, give or take getting a after market LSD isn't required until it explodes
Old Feb 9, 2007 | 01:52 AM
01 Sierra's Avatar
hmmmm ya i figured getting a LSD now or putting in a 5.3l or S/C it i need more power...and i never realized how much a stall will help how hard are those and how expensive are they?
Old Feb 9, 2007 | 01:59 AM
LesPaul's Avatar
this is just my opinion and im sure more will chime in at a more normal hour.. but if i was going to swap in an engine it would be the 6.0, if your going through all the trouble why not?? second, you put a s/c on it that will run your around $5000 for an uncooled set up, for the price your better off getting a 6.0 and a built tranny right away, and for that matter put in a stall why the tranny is out... i payed $500 for mine... but on the other side i noticed from your other thread you were from cally, if you want something that will make nice power and pass emissions i would put a s/c on a 4.8.... its really up to you... like many others on here my set up is nowhere near street legal but i drive it everyday well when its not broken any how
Old Feb 9, 2007 | 02:03 AM
01 Sierra's Avatar
ya thats the problem is that california wont allow an engine in a car that the engine wasnt made for...and although the C3 sierra had the 6.0 im not sure im aloud to use it...
Old Feb 9, 2007 | 02:05 AM
LesPaul's Avatar
are they really that wise tho... the only way to tell the difference between the 4.8 and 6.0 is the casting number on the heads
Old Feb 9, 2007 | 02:18 AM
01 Sierra's Avatar
hmmm i did not think about that....well its definetly something i will be looking into....
Old Feb 9, 2007 | 09:12 AM
12secSS's Avatar
You can put in a 4.8L, 5.3L, 5.7L or a 6.0L in any year truck from 1999-2007. Since they are trucks and all had the option of these engines (less the LS1 5.7L, see below), you can swap it in. C.A.R.B. doesn't care about what engines were available with what model specific platform, just that the platform had it as an option. Hell, you could replace you diesel with a 6.0L if you wanted to.
Since the LS1 5.7L is a passenger vehicle engine, it can go into a truck without worry, but a truck engine can not go into a passenger vehicle. FYI, I swapped my LS1 (#5 lost compression) with an LQ4, it was an easy remove and replace swap.
I am in Ca as well, where are you located? I can show you what is needed to swap the 4.8L with a 6.0L, as my truck has a 6.0L. Plus I can help with the tune, since I have HPTuners for all trucks.
Old Feb 9, 2007 | 02:46 PM
slowec's Avatar
do the 6.0! It IS worth it!!!
Old Feb 9, 2007 | 06:05 PM
01 Sierra's Avatar
im down in the 661 area code right above los angeles sorta...ya let me know and if u know were to get a cheap 6.0 that would be great to thanks guys
