4.060" bore why or why not.
Old Feb 12, 2010 | 03:30 PM
pewterliftedz's Avatar
Default 4.060" bore why or why not.
alright guys im looking into a 6.0 for the truck..
since i am planning on getting a motor completely rebuilt, i figure why not bore it .03 or .06.
i haven't heard anyone using 4.06" bore, will my temp be higher like the problem guys run into with iron 5.7's.
whats the capabilities of the cylinder wall on a IRON 6.0 block..
any info is good guys, thanks.
Jason
EDIT: this is for a DD N/A mild setup, im shooting for 400rwhp..
Old Feb 12, 2010 | 10:00 PM
anyone..
Old Feb 13, 2010 | 10:47 PM
built408's Avatar
Your not going to make much more, if any power doing it. But if you want to then go ahead, you won't have any problems with a 4.060 bore.
Old Feb 13, 2010 | 11:01 PM
Mangled03gmc's Avatar
Baltimore Whore
I think alot has to do with the fact that is something would happen internally, maybe going with a smaller bore, you could resort to the .06 bore to save the block.. I am not sure how much you can safely go on a 6.0, on the 5.3's you start getting very thin on the cyl walls.. Your not getting that much more out of it, why not just stroke it if your looking for the extra cubes??
cool man... i guess if i end with a motor that needs to be rebuilt i'll do a 4.06" bore... if not i'll just stab the stock 4" bore in there
Old Feb 13, 2010 | 11:03 PM
well mangled, iv just looking to uild a motor thats gonna last me another 100K.
from what iv heard strokers have more issues.. what do u think..
Old Feb 13, 2010 | 11:10 PM
Baltimore Whore
There is no issue doing a 30 over motor.. But once you go 60 if something should happen, you are not going to have much to over bore it if a cyl is messed up.. Strokers tend to burn oil more so then others. Alot form what I gather is improper piston, rod set ups, which cause alot of piston rock at the bottom of the stroke..
Old Feb 13, 2010 | 11:16 PM
good info, thanks mangled
Old Feb 14, 2010 | 10:14 AM
batboy's Avatar
11 Second Club
I agree, no problem with a 0.030" over bore. But, going 0.060" might be pushing it a bit, thinning the cylinder walls, etc. Generally, I like to bore out a block just the minimum, that way you can bore it out again later if needed.
Old Feb 17, 2010 | 10:40 PM
BigHate's Avatar
i have .040 over on my lq9. so far so good. #8 had a scratch on the wall so they bored till it was gone. i would have kept it the stock bore though if i could have
