292 to 454 swap
Old Jul 26, 2019 | 05:39 PM
mark5251993's Avatar
Registered User
Default 292 to 454 swap
i have a 1966 c10 with 292 that's knocking bad and i believe i have a nv3500 5 spd out of a newer model truck that had a 350 in it so i'm going to swap a 454 out of a 75 with a turbo 400. so my questions are can i keep the 5spd and if so how much will need to change everything looks pretty close mounts and such but what about the fly wheel? this is my only drive able truck so i need help quickly to get back on the road any help would be greatly appreciated thank you in advance
Old Jul 27, 2019 | 11:30 AM
_zebra's Avatar
makes children cry
the nv3500 will bolt up to any GM bellhousing pattern, and i've seen a guy that goes by something like xx_Ed_xx that put a 454 & a turbo 8.1 in front of his nv3500 just fine.
you can dig around & find his build thread to see what flywheel/clutch he used to make it happen.
Old Jul 27, 2019 | 03:31 PM
Registered User
Default I'm trying to get it done as cheap as possible
I'm trying to get it done for as cheap as possible so if I can use the clutch and everything I have that would be great
Old Jul 29, 2019 | 06:30 PM
Registered User
Default Th 400
I'm considering putting the th400 in and am wondering if anyone else would do this to their daily driver and how bad the gas mileage would be
Old Jul 29, 2019 | 08:36 PM
MikeGyver's Avatar
I'm sure that I'm not the only one who would rebuild the six. That's a special truck you have.
Old Jul 30, 2019 | 01:00 AM
Registered User
Default Rebuild
I'm going to rebuild the engine when I have the money to do it right. My dad bought the truck from a family friend who's grandpa bought it new and I got it from my dad with the promise that I wouldn't sell it and keep it in the family. I'm only trying to get it back on the road again it's my only vehicle. I'm extremely proud to own this truck.
Old Aug 18, 2019 | 11:44 AM
Registered User
Default 454 swap
I finally got the straight6 out I pulled the front clip to make it easier I was really surprised that it was that easy to get the clip off.I'm working on getting the 454 and trans out of the 75 Winnebago icatsa
Old Aug 18, 2019 | 04:52 PM
ZO6Ted's Avatar
That's gonna be a bad little truck. I've had 2 65's one with a 350 and the other with a 400 sb and a 67 292. I'd dang sure do it! I think that yr model 454 has possibly 049 heads but probably 781's which are some of the exceptional oval ports. I'd do the 400 and use a tall tire! Carry on...gonna be fun.
Old Sep 26, 2019 | 01:01 PM
Registered User
Default I have the engine and trans in
I got the 75 steering column to fit with no modifications other than changing the turn signal wiring I made the rod to connect the column to the steering box it turned out great. I have had to build mounts and linkage but it's in the truck it's about ready to run and drive a few more things to do gas pedal power steering line and a lower radiator hose, wiring the electric fan up to a relay all the little odds and ends.
BC496
Sep 6, 2017 10:45 PM
92C1500
Jan 24, 2017 09:21 PM
lukn4trbl355
Sep 17, 2014 09:17 PM
lukn4trbl355
Jan 24, 2013 10:34 AM
maxpower420
Feb 6, 2010 11:49 PM
