2013 GMC LQ4/243 heads
Old Jun 29, 2014 | 02:45 PM
  #21
GWEE's Avatar
Damn guess im on the look out for a 07-up 6.0L with harness ect ect.
Might have to change my sig too lol
Old Jun 29, 2014 | 02:47 PM
  #22
slammedchevy's Avatar
That's your best bet make sure it's a 07 from a gmt 900. 07 had split years
Old Jun 29, 2014 | 03:01 PM
  #23
GWEE's Avatar
Yes sir thanks
Old Jun 29, 2014 | 03:33 PM
  #24
No problem man anytime.
Old Jun 30, 2014 | 09:46 AM
  #25
GWEE's Avatar
Ok so this is what i need to swap a V8 in my V6 truck. A GenIV engine like LY6, LS3, L94, L76, LSA, LS7 and LS9 with the computer and wiring harness. Chance front drive system plus fuel lines and fuel pump. And of course the motor mounts and im sure a few other things ill find along the way.
Old Aug 9, 2014 | 11:21 PM
  #26
GWEE's Avatar
Ok i also read ill need these items to go from v6 to V8 and looking at a LS2
Refrigeration lines
Fuel lines
radiator/efans
radiator and heater hoses
4L80 crank spacer if new enough to keep OE v6 tranny
or swap bell housing and front pump on existing tranny
v8 transmission dipstick tube
Harness pcm/tcm thats exact year of vehicle to keep gremlins to a minimum
motor mounts.
If you go 6 speed and want to keep tap shift gotta go to uplevel bcm and swapcluster and shift handle and flash for appropriate year model and options closeto existing truck.
reflash fuelpump control module for v8 truck
The E38 and the E67 ECMs are both only used on 58x Gen IV V8 engines (as well as 4 cylinder and 6 cylinder applications).
Old Aug 9, 2014 | 11:23 PM
  #27
GWEE's Avatar
Double post
Old Aug 10, 2014 | 11:15 AM
  #28
zero2sixT's Avatar
You'd be money ahead by selling your 2013 and buying a rcsb with a v8 already in it. I don't think you realize all the work and money involved in this swap.
The computer in my '03 is a slow piece of ****. I would never swap a newer computer for an older one.
Also, there is a box that will allow the computer for a newer engine work with a 24x reluctor wheel. Lingenfelter makes one, not sure who else.
Dan Neumann
11
Aug 7, 2022 09:06 AM
zo6freak
14
Oct 18, 2015 06:43 PM
thewrx
Aug 12, 2015 08:28 PM
Three6GMC
Aug 3, 2015 07:53 PM
BIGD4504
Jul 28, 2015 11:46 AM
