2013 GMC LQ4/243 heads
Old Jun 28, 2014 | 10:15 PM
smokeshow's Avatar
Mod with training wheels
Originally Posted by GWEE
Ok thanks for the heads up. I thought if i used the harness and computer from the LQ4 it would work in my nnbs. Again thanks
Lol, technically you could... But it would be more work than its worth. I've done it before, but the other way around.
Old Jun 28, 2014 | 10:41 PM
GWEE's Avatar
Oh and just so yal know my trucks a V6 not a V8 not sure if that makes the swap idea better or worst.
Old Jun 29, 2014 | 02:02 PM
slammedchevy's Avatar
Originally Posted by Blk09Chevy
99-07 nbs have the 24 reluctor wheel. all the newer 07+ have 54 reluctor wheel it will work in and older truck but not yours unless you plan on swapping out cranks but you might as well get an ly6 and have a plug and play engine that you still could use the heads on
It's a 58x not 54 lol but I think he still has bigger problems being he is a v6 also
GWEE's Avatar
I'm still trying to wrap my head around this. If i have the engine, harness and computer from the 03 2500 ( LQ4 GenIII ) truck why can't i put it in my 2013 truck. I thought the computer runs the engine. Guess my main question is why i see people putting LS base engine of all years in muscle car, classic car and older trucks ( pre 90 ) but i can't put it in a newer truck? Thanks
Old Jun 29, 2014 | 02:03 PM
GWEE's Avatar
What other problems i might have?
Old Jun 29, 2014 | 02:10 PM
Your truck is to new to run the 99-07 harness. To many computers that use signals from your PCM now. People take the the harness you have and make it a stand alone to work in older stuff that don't need abs and body control inputs and outputs. You need to find a 07 and up gmt 900 harness and buy a new motor with a 58x wheel or have your 6.0 changed to 58x but that's done from a machine shop.
Old Jun 29, 2014 | 02:15 PM
I should have reworded that a little diff. Not bigger problems. Just other problems But fuel lines will be different not a big deal. I'm sure there might be a couple little things but nothing that's not doable.
Old Jun 29, 2014 | 02:25 PM
GWEE's Avatar
Maybe i should have point that out. I plan on changing the fuel line and changing the fuel pump in the tank. I have about 3 or 4 damaged trucks to take parts off like mentioned about plus A/C comp, all front drive parts and cable style TB. Thanks for ALL the comments i do really appreciate it.
Old Jun 29, 2014 | 02:34 PM
GWEE's Avatar
Thanks
So if im reading this right i have muti computers in my newer truck that need to all work together. Please excuse my ignorance.
Old Jun 29, 2014 | 02:42 PM
[QUOTE=GWEE;5227408]Thanks
PCM uses signals from abs and bcm. They all work through can. I have not compared diagrams side by side but I can bet there is a lot of wires that are in different locations.
