2006 Silverado will not crank. How odd.
Old Aug 10, 2013 | 09:17 PM
NO F-BDY BS's Avatar
Default 2006 Silverado will not crank. How odd.
Nothing leading up to this. Battery is good, good connections, starter is not dragging.
Went to grocery store, stopped again at a gas station on the way home to get some Sprite. Got back in. All dash lights, a/c radio, windows, horn, ect. All work. Nothing at the ignition/key switch.
I know the usual suspects, what I dont know, is the the security/anti-theft issues that could prevent it from cranking. It was dark when i got it home, so I didnt get a chance to check any fuses, or check any connections to the starter. I do think I hear the selenoid click when I hit the ignition.
Where should I start?
Old Aug 11, 2013 | 12:06 AM
Suburbazine's Avatar
If you hear the solenoid hitting, then you probably need to replace the starter. Most likely the contactor in the solenoid has failed.
There's a possibility the power cable under the oil pan has corroded out but it is usually more intermittent than not at all.
Old Aug 11, 2013 | 08:26 AM
bbowerman's Avatar
does the gear selector say P if not it could be a "pnss" park neutral safety switch try starting in neutral. if it says p it should be alright though
Old Aug 11, 2013 | 09:43 AM
Yeah, thats all good. No dice in N either.
Got my wife to cycle the key, i can def hear the solenoid hitting.
Old Aug 11, 2013 | 10:23 AM
Gadgetized's Avatar
I would check all the grounds again just to be sure. Back of both heads, and the one on the drivers side pan rail as mentioned above.
Old Aug 11, 2013 | 12:36 PM
Will do. Gonna be home in a bit, and see what i can find out.
Old Aug 12, 2013 | 08:23 PM
Chevygearhead84's Avatar
Have you tried tapping the solenoid while your wife holds key in start position? Grounds are a good thing to check too.
Old Aug 12, 2013 | 08:37 PM
726.0chevelle's Avatar
13 Second Truck Club
I had that same exact problem I would have changed the ignition switch but I was out town working and didn't have time to wait on ordered parts. I dropped the truck off at the dealership they replaced the battery and the ground lead. The battery was not that old and the main ground wire looked near perfect. I think the problem was the ground wire the whole time.
ARC
57
Feb 21, 2022 10:54 AM
B.love18
Sep 21, 2015 08:31 PM
1bad2k
Aug 18, 2015 09:50 PM
walledition
Jul 29, 2015 08:54 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
