2005 Gm Trucks?
Old Dec 29, 2004 | 09:22 PM
zippy's Avatar
any truck that can almost hit the speed limiter in second gear has too high of a gear. i've driven both a 3.42 and a 4.10 geared version. it's deffinitly noticable and once you begin to mod it, the results will be even greater. your rpm at a 70 cruise in something that big and heavy with that few cubic inches doesn't need to be below 2000rpm.
Old Dec 29, 2004 | 10:49 PM
14 Second Truck Club
Who wants to get together a parts list to swap over to the 05 front brakes? Master cylinder, proportioning valve, booster,..... I wonder if you can get the old rear discs to work with the new fronts. Which proportioning valve would work best?
Inquiring minds need to know.
Old Dec 29, 2004 | 10:59 PM
James B.'s Avatar
The new brakes are designed completely by Bosch, not GM. Literally EVERYthing is different. Taking the differences in volume and pressure between the two systems which has to be vastly different, I don't think the newer calipers would receive a proper feeding from the old GM-design master cylinder and booster. The rears would be a proportioning nightmare.
Old Dec 29, 2004 | 11:12 PM
GREGGO's Avatar
Deep Skirt Aluminum Block with cast in place steel sleeves. This is basically a 6 bolt main where the block extends below the crankshaft center line allowing for more rigidity and two more main bearing cap bolts to enter from the sides. The old hemi's and American motors used deep skirt blocks.
Nothing new other than the aluminum here. I'd like to know the new cam specs though.
Old Dec 30, 2004 | 05:09 AM
sfj
you might ask one of the GM mechanics or workers on the site about the exact motor differences i remember stupidfast told me what they were but do not remember exactly what the difference was other than the 10 hp
Old Dec 30, 2004 | 05:10 AM
Faze2183's Avatar
interesting
Old Dec 30, 2004 | 04:33 PM
revolution's Avatar
they also have a "lifetime" in-tank fuel filter. what's the new cr? actually... what was the old 03-04 cr?
Old Dec 30, 2004 | 11:52 PM
Faze2183's Avatar
Old Dec 31, 2004 | 12:20 AM
Where did you hear they had the LS6 heads?
Old Dec 31, 2004 | 12:21 AM
James B.'s Avatar
This has me baffled. In the press release they claim that a smaller filter can be used with the returnless fuel system. So I guess if you have a truck with the returnless fuel system the fuel dispenser at your gas station senses it automatically and gives you fuel with less dirt in it! Of course! Stupid me...
My 'Hoe hit 62K this month. I'm on my FOURTH fuel filter.
