2001 tahoe 5.3 to 6.0
Old Apr 3, 2012 | 12:21 AM
50kta's Avatar
Default 2001 tahoe 5.3 to 6.0
i need to replace to 5.3 in my 2001 tahoe, so why not upgrade to the 6.0? so my question is do i need the computer for the 6.0 or can i use the stock computer in my tahoe that "ran" the 5.3 and it will "run" the 6.0 as well?
Old Apr 3, 2012 | 12:30 AM
AndysC3's Avatar
It will need a tune for the 6.0. But the computer from the 5.3 should work.
Old Apr 3, 2012 | 03:25 PM
Cknox121's Avatar
Your gunna love it! Just swapped a 6.0 in my 01 ecsb and it will freaking fly! Next is the TBSS swap
Old Apr 3, 2012 | 03:27 PM
nonnieselman's Avatar
Yep, get a tune from a sponsor to the right and have fun.
You goin LQ4 or LQ9?
http://www.gowheatley.com/
http://www.blackbearperformance.com/
Old Apr 3, 2012 | 05:39 PM
50kta's Avatar
im just going to get a 6.0 dont really matter if its a lq4 or lq9 . its just a dayly driver.
Old Apr 3, 2012 | 08:55 PM
erikwiski's Avatar
Registered User
I have a 2002 GMC Sierra truck with a 4.8L Vortec V8 in it now i am looking to swap that out for a vortec 6.0l lq9 or lq4. I've heard everything will bolt right up and all my computers will work (after flashing computer) i have also heard that i need to find the 6.0 out of a certain year make and model vehicle to make sure everything will swap right over easily.
I need help with what vehicle year make and models have the correct 6.0L in them to correctly swap with my 4.8L ... please lay some knowledge on me so i can find the correct motor and start making some real power!
Thanks
Old Apr 3, 2012 | 09:10 PM
TIM Z's Avatar
11 sec. Truck Mod
Thanks
The early 6.0's had iron heads and a crank end that will only mount up to a 4L80E, i know 99' for sure is this but might be 00-01 also. Just look for an 03' up and you will be fine. The later engines have the 317 alum heads and only the flexplate needs changed to run a 4L60E .Good luck.
Old Apr 3, 2012 | 09:13 PM
erikwiski's Avatar
Registered User
good to know thanks tim!
Old Apr 4, 2012 | 08:42 PM
chacho44's Avatar
I wonder how one will run with a 6.2
Old Apr 4, 2012 | 10:01 PM
1Bear's Avatar
The 2001 thru 2007 Classic model truck 6.0Ls all have the 317 casting aluminum heads, short crank for use with a 60E and a 24-tooth reluctor wheel.
Only the 1999 & 2000 models have the iron heads and long crank.
