2001 5.3 with a Magnacharger
Old Apr 21, 2004 | 03:51 PM
LBSBLOWN's Avatar
Default 2001 5.3 with a Magnacharger
Hi,
New to this site.
I posted on the Forced Induction board also.
I have done a search but have not found an answer.
I have a 2001 4X4 Suburban with a 5.3 and a Magnacharger (the first system
that dosen't have a Intercooler).
Here's the Question:
What Spark plugs should I run, I still have the Factory AC 41-985 plugs.
I would like to run 2 steps cooler but I can't find a plug # for the
AC Iridiums 41-900 series plugs that is two steps cooler.
As I understand the new numbering system used by ac delco has nothing
to do with heat range of the plugs.
Magnacharger just said to use the stock plugs, I would rather find a two
step cooler plug, I have a little spark knock going on.
Thanks for the help in advance.
Old Apr 21, 2004 | 03:57 PM
954RR's Avatar
Originally Posted by LBSBLOWN
Hi,
New to this site.
I had the same exact kit. I ran NGK TR55's and they worked great. Gapped them at .35
Old Apr 21, 2004 | 04:00 PM
BlownChevy's Avatar
blownerator
25 Year Member
You beat me too it!
Old Apr 21, 2004 | 04:08 PM
954RR's Avatar
Originally Posted by BlownChevy
You beat me too it!
I bet that doesn't happen every day.
I would leave this blower at the stock boost 5.5lbs if I remember right. Unless you plan on getting LS1 edit and put a very good tune to it. Or just run a little paint thinner in your gas if you go to the track.
You will get KR anything over 7lbs on 80 and above days that is for sure and if you don't belive me on this look at these picts. 91 octane gas + 85 degree day + outrunning Lightening on the interstate = a broken #7 piston.
Attached Thumbnails 2001 5.3 with a Magnacharger-truck-picts-014.jpe   2001 5.3 with a Magnacharger-truck-picts-015.jpe
Old Apr 21, 2004 | 04:11 PM
BlownChevy's Avatar
blownerator
25 Year Member
Yikes!
Old Apr 21, 2004 | 04:46 PM
Hit Man X's Avatar
Yikes!
hahahah
Old Apr 21, 2004 | 04:48 PM
954RR's Avatar
Originally Posted by Hit Man X
hahahah
Ya I thought it was pretty funny too
It will be running this weekend before with more hp NA than I had FI
Old Apr 21, 2004 | 04:56 PM
BlownChevy's Avatar
blownerator
25 Year Member
SAAWEET! What C/R did you end up with?
Old Apr 21, 2004 | 05:41 PM
954RR's Avatar
11-1 So no boost for me!!!
Project boosted/forged 427 is already underway though have lots of parts so far.... just reasearching and saving!! won't be going in my truck though, have another project that is 2wd.
Old Apr 21, 2004 | 05:56 PM
BlownChevy's Avatar
blownerator
25 Year Member
SLOPONY
20
Oct 18, 2016 06:05 AM
Knightcrawler
Jul 20, 2016 03:29 PM
mikeyjm1
17
Oct 29, 2015 11:04 PM
rojeho
Aug 8, 2015 07:20 PM
