15 Silverado 5.3 to 6.2 top end swap
Old Mar 23, 2017 | 11:50 PM
fmank72's Avatar
Default 15 Silverado 5.3 to 6.2 top end swap
Local shop recommeded swaping out top end for 6.2. Has anyone done this what kinda numbers coukd i see eith a tune. Mentioned needing a throttle body adapter for 6.2 intake to jive. A budget upgrade???
Old Mar 24, 2017 | 01:27 PM
Drspencer's Avatar
5 Year Member
Like....the heads? Aren't the combustion chambers bigger? Unless you're sticking a GM blower on it...is there a point?
Old Mar 24, 2017 | 01:46 PM
03sierraslt's Avatar
1- I am not sure the valves would clear the bore
2- if they do the shrouding would be horrible
But hey, someone prove me wrong.
Old Mar 24, 2017 | 02:00 PM
ezdaar's Avatar
stay far away from that shop.
Old Mar 24, 2017 | 02:57 PM
Tig's Avatar
Tig
Maybe he meant swap from the 5.3 to a 6.2
Old Mar 26, 2017 | 08:33 PM
ZO6Ted's Avatar
As above, I don't even think its remotely possible bc of the large valves. If it was I would've already done it...head flow.
Old Mar 26, 2017 | 08:43 PM
Brianwilson1990's Avatar
Registered User
I have a friend who did this swap. Heads and intake from a l92 onto a 5.3. He used the l92 head gaskets because the 5.3 gaskets didn't clear his valves when he matched them up. That should have been his first clue. But it wasnt. He tried to fire it up. I think he only bent a few valves before the starter couldn't turn it anymore
Old Mar 29, 2017 | 07:49 AM
Drspencer's Avatar
5 Year Member
But the 5.3 head gaskets are the same size as the bore of the engine....c'mon....
