102mm dbw
Old Feb 21, 2019 | 07:23 PM
03sierraslt's Avatar
You need a PCM that supports IAC circuit, most don’t. Mines from a 04 express van. Supports DBC, DBW, 3bar and flex fuel.
Old Feb 21, 2019 | 10:00 PM
Go5.3tt06's Avatar
should i stay dbw and use stock truck throttle? Also plan to run ms3 pro too
Old Feb 27, 2019 | 03:29 PM
Go5.3tt06's Avatar
you need a pcm that supports iac circuit, most don’t. Mines from a 04 express van. Supports dbc, dbw, 3bar and flex fuel.
can you suggest me what should i do with throttle, and i can order some and start process?
Old Mar 1, 2019 | 11:47 AM
Vortec350ss's Avatar
The 90mm I think is fine on a 6.0 or similar, but on a 427 that would see gains NA from a 102, I think it will also see gains with a turbo. Same can be said for a 6.0 swapping from a 78mm TB and intake to the 87mm TB and intake. I haven't heard of issues with blow through compressors (centrifugal supercharger or turbo) with the 102mm throttle bodies. That doesn't mean they don't exist, but I haven't seen them first hand.
If it was my truck, I think I would still try the X link and 102 boosted. The velocity of air moving past the throttle blade will be much slower than what Pat was dealing with on his 370 and 2300 TVS. The density and air volume will be far greater, but something tells me its the velocity that plays a more significant role in the throttle blade fluttering. Thats just a hunch though.
Old Mar 4, 2019 | 12:31 PM
Go5.3tt06's Avatar
https://www.ebay.com/i/292823287646?chn=ps dont you think this is junk>
dounome
Jan 29, 2015 10:50 PM
LS1DIME
Mar 10, 2014 10:05 PM
Three6GMC
Sep 18, 2013 06:36 PM
Iraq Sucks
Aug 27, 2013 09:40 PM
supersub
13
Jun 18, 2011 09:44 AM
