102mm dbw
Wonder this will work on my 2006 silverado high ram intake for that, what about harness adapter I cant find it. If you can help me out? I dont want use my stock one truck throttle. I have lsx427 in work on turbo need a good throttle.
I haven't had a problem with my NW 102mm at 17lbs. I'm using dominator EFI though. I think the people running aftermarket ECUs have better luck with them over people using the stock ECU.
On my turbo setup I am just running a LS2 90.
90mm will support a lot of power on a blow through setup. I got tired of the damn issues with 102’s, the DBC 105 worked good but I like the tunability of DBW.
i have a Hi Ram on mine also.
how about swap drive by cable and will tune delete code like abs, brake light on if swap Dow to cable??
