07 SIERRA NBS heads, cam and torque converter
Old Aug 26, 2012 | 12:21 PM
TheTechnician's Avatar
Default 07 SIERRA NBS heads, cam and torque converter
Hey guys, looking for heads, cam and torque converter.
Found a Comp cam: P/N 54-500-11 Operating Range: 1800-6400 RPM
Duration Advertised: 270° Intake / 277° Exhaust
Duration @ .050'': 235° Intake / 240° Exhaust
Valve Lift w/1.7 Rockers: .646'' Intake / .641'' Exhaust
Lobe Separation Angle: 113°
Circle D torque converter: 4L60 LS HP Series Stage II 278mmTorque Converter Diameter: 278mm - 11"
Stall speeds 2600 to 3200 RPM
Hand TIG Welded
High Carbon Spun Wound Lock-Up Clutch Lining
Heavy Duty Torrington Bearings
CDS Custom Bearing Retainer
*Thinking of 3000-3200rpm stall*
I cannot find any set of decent heads yet, looking for bit of an insite towards them. Any ideas? Also hows the current set up looking? Thanks!
Old Aug 27, 2012 | 01:26 AM
Perhaps instead of buying heads, should I consider port and polishing my stock ones? Pros/Cons?
Old Aug 27, 2012 | 02:46 AM
iamkeniff's Avatar
That cam is too big for that truck with that small of a converter and lack of gear muchless that 5.3. It'd be a complete turd an you may have to flycut the pistons for clearance of the valves.
How about you give some ideas or a goal that you are tryin to reach and do more research. Honestly i wouldnt go past a 228 intake on a 5.3 with a 3800+ converter and 4:30+ gears.
P&P heads would be fine if you can find someone good enough to do them. Id just send them to Texas Speed for a cnc and valve job imho
Old Aug 27, 2012 | 04:13 AM
AndysC3's Avatar
That cam is huge for a 5.3L. Im running a 227/235 .612/.624 113LSA and its alittle on the big side. Something around a 224 would be more suited for the 5.3 and still have decient road manners. and that would need about a 3400 rpm converter to be happy.
Old Aug 27, 2012 | 05:19 AM
Petey62782's Avatar
MASS seller approved
I would look into comp XR265 cam. I believe it's 216/218 . And that's a tried and proven cam by members on here with 4.8/5.3's.And if you want a lil more lift than contact PatG and spend the small fee of 25$ and get a custom spec cam. I had him spec my cam and he is spot on I have great power down low and all they way up. Either way that cam ur looking at is more suited for a 6.0 or bigger with a 4000 stall in a much lighter Fbody or something. You 5.3 would become a anchor with that cam.
Old Aug 27, 2012 | 07:07 AM
Jake Wade's Avatar
As the others have mentioned, What are your goals for the truck? Is this a daily driver? Do you tow? Is gas mileage a factor?
The cam you chose is HUGE and the converter is a mis match.
Let us know how you really will be using the truck and you will get some good solid feedback here.
Old Aug 27, 2012 | 03:15 PM
Hey guys thanks for the replies. Ok so gas mileage isn't really a factor as long as its not super terrible. It will be a daily driver and I don't usually tow a lot. I don't race very often but I want some power when I need it. This is why I came here, I'm getting good feedback here. Got a quote to CNC port my stock heads. Looking at around $2000. Little steep as I found some decent heads starting at $1400.
Old Aug 27, 2012 | 03:54 PM
Spoke to comp cams, told me the XR265HR 212/218 would be perfect for stock top and bottom end with a 1800-2000 stall max and if I were to do heads I should find a little more aggressive cam. The XR269HR is 216/220 and the XR273HR 220/224.
Old Aug 27, 2012 | 05:46 PM
Jake Wade's Avatar
Your on the right track now. That cam is a proven performer for a daily driver without alot of other needed additions.
Here is a good read:
5.3L LS Small Block Build - Here Comes Modern Mouse! - Super Chevy Magazine
Old Aug 27, 2012 | 06:42 PM
726.0chevelle's Avatar
13 Second Truck Club
I would get a nice set of long tube headers before buying cylinder heads.
