01 yukon motor swap! help please
Old Feb 8, 2011 | 05:57 AM
cnukpup's Avatar
Default 01 yukon motor swap! help please
hi everyone i have a 01 yukon that i need to swap a motor (bad rod) i have a 5.3L 4x4 4l60e i found an 05 5.3L (lm7) motor that i want to get but not sure if it will work in my truck? and dont know what LM7 is? can anyone help please Thank you so much. Tom
Old Feb 8, 2011 | 06:44 AM
Bigredmariner's Avatar
The LM7 is a gen 3 Iron block with aluminum heads. It should work just fine for you. Look in your glovebox at the option sticker. Chances are you had a LM7 in your ride already. Good luck.
Old Feb 8, 2011 | 04:00 PM
cnukpup's Avatar
great thank you! one more question will it be in plain sight on the sticker?
Old Feb 8, 2011 | 04:41 PM
nickleahy23's Avatar
why not find a 6.0 and swap it in? its basically the same swap..might as well up the power while you are at it
Old Feb 8, 2011 | 09:19 PM
cnukpup's Avatar
to do a 6.0l swap what would be needed? i did think about that. just not sure what it would take
Old Feb 8, 2011 | 09:45 PM
bluebommer07's Avatar
if mem. serves its a direct swap, not sure but somone will chime in
Old Feb 8, 2011 | 09:59 PM
cnukpup's Avatar
i thought i heard you need to change the computer? not sure. any thought would be great know before i buy the 5.3l
Old Feb 8, 2011 | 10:56 PM
fredkj3's Avatar
direct swap.. it will run on your stock tune.. i ran around for 6 months with stock tune when i did my 6.0 swap...
Old Feb 9, 2011 | 12:37 AM
ya direct swap as long as it is 2001-2007 i believe? 99-00 has a longer crank and wont work...have to change the flex plate on the 6.0 to the one on your 5.3, but thats about it..you might as well get a blackbear tune to go along with the new motor, so that would take care of your computer
Old Feb 9, 2011 | 06:20 PM
fredkj3's Avatar
you dont want that motor anyways. those are the iron head motors.
OHsixLS3
Dec 27, 2016 09:30 AM
CammedZ71
Aug 2, 2015 01:44 AM
Ketis
Jul 23, 2015 12:37 PM
Rwilliams85
Jul 14, 2015 04:36 PM
Nimoryan
Jul 5, 2015 03:50 PM
