01 yukon motor swap! help please
hi everyone i have a 01 yukon that i need to swap a motor (bad rod) i have a 5.3L 4x4 4l60e i found an 05 5.3L (lm7) motor that i want to get but not sure if it will work in my truck? and dont know what LM7 is? can anyone help please Thank you so much. Tom
The LM7 is a gen 3 Iron block with aluminum heads. It should work just fine for you. Look in your glovebox at the option sticker. Chances are you had a LM7 in your ride already. Good luck.
ya direct swap as long as it is 2001-2007 i believe? 99-00 has a longer crank and wont work...have to change the flex plate on the 6.0 to the one on your 5.3, but thats about it..you might as well get a blackbear tune to go along with the new motor, so that would take care of your computer
CammedZ71
Aug 2, 2015 01:44 AM
Nimoryan
Jul 5, 2015 03:50 PM
