*Urgent* Need help truck won't start!
Old May 29, 2005 | 04:17 PM
tdrumm's Avatar
Angry *Urgent* Need help truck won't start!
I've just finished buttoning up my cam swap, put in the new PCM, and the truck tries to start but shuts off almost immediately. I've done the PCM learning trick multiple times, but it doesn't work.
Help!!!!
Old May 29, 2005 | 04:23 PM
2002C5COUPE's Avatar
what size cam??
i ended up having to drill a small hole in my TB plate to get it to idle
Old May 29, 2005 | 04:24 PM
make sure you never turn key off during passkey relearn,it will start on 4th try.it will take at least 30 minutes to learn.
Old May 29, 2005 | 04:30 PM
BigBlockChev572's Avatar
Help!!!!
Have you cranked it, let it die, pulled the negative terminal, screwed it back in and cranked it?
Also, I've heard some people just put their foot in it when it starts for a second and hold it at X RPM for a while then let it idle back down.
Philip S.
Old May 29, 2005 | 04:35 PM
tdrumm's Avatar
FWIW, it starts and idles just fine with the stock PCM.
Old May 29, 2005 | 04:41 PM
try passkey learn exactly as described
Old May 29, 2005 | 04:44 PM
tdrumm's Avatar
Is this the turn the key to on for 11 minutes, then off for 30 seconds, repeat two more times and it should start on the 4th try? If it is I've already tried it
You say not to turn the key off, but my instructions to turn it off. Should I just turn it to ACC?
Old May 29, 2005 | 04:56 PM
TRY TO START,TRUCK DIES,LEAVE KEY ON ,SECURITY LIGHT STAYS ON,WAIT TILL SECURITY LIGHT GOES OFF ON IT,S OWN,TRY RESTART AGAIN,ETC. WILLSTART ON 4TH TRY.
Old May 29, 2005 | 05:55 PM
tdrumm's Avatar
It's alive!!!!!! Thankyou so much.
Old May 29, 2005 | 05:58 PM
Glad I could help
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
