*Urgent* Need help truck won't start!
I've just finished buttoning up my cam swap, put in the new PCM, and the truck tries to start but shuts off almost immediately. I've done the PCM learning trick multiple times, but it doesn't work.
Help!!!!
Help!!!!
Help!!!!
Help!!!!
Also, I've heard some people just put their foot in it when it starts for a second and hold it at X RPM for a while then let it idle back down.
Philip S.
Is this the turn the key to on for 11 minutes, then off for 30 seconds, repeat two more times and it should start on the 4th try? If it is I've already tried it
You say not to turn the key off, but my instructions to turn it off. Should I just turn it to ACC?
cams 98 silverado
Jul 31, 2015 07:36 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
