with zero experience
Old Apr 19, 2006 | 09:53 PM
moregrip's Avatar
what a rush!
Default with zero experience
how hard would it be for me to rebuild my 4l80e myself?
Old Apr 19, 2006 | 10:04 PM
Bowtie70SS's Avatar
I have wondered that myself. I have been wanting to do some tech school classes on trans rebuilding. I would think it can't be too tough. Get a trans service/shop manual and have at it. Keep us posted...Look at the money you would save you can get a bad *** rebuild kit for what $250? The trans shop gets what $1000 to do it? I think they can only charge that much because transmissions are like chinese algebra to most people.
Dave
Old Apr 19, 2006 | 10:06 PM
goshawk23's Avatar
Truck addict
don't do it. spend the money. if you search different forums you will find a builder that will save you money and will be competent at the same time. a lot of tranny builders that work for other peoples shop will build them on the side at their house for a lot less money just to help make ends meet. granted, you might not have a warranty because of such arrangement but if you are looking to save cash it can help. also, pm litreddevil about building a tranny. he does it for a living now and can tell you the in's and out's.
Old Apr 19, 2006 | 10:07 PM
goshawk23's Avatar
Truck addict
Dave
my badass rebuild kit cost me 650! for a 4l60E. there is more to it than reading a manual. i wish it wasn't so but it is.
Old Apr 19, 2006 | 11:24 PM
moregrip's Avatar
what a rush!
any other thoughts?
Old Apr 19, 2006 | 11:34 PM
James B.'s Avatar
I did it. It doesn't need any specialized tools. The Overdrive piston is difficult to get back together while trying to protect the piston seals. For that I used overhead tansparencies cut into strips. I used sockets to pound out the old bushings and to install the new ones. The piston springs can be compressed in a vise to get the snaprings back in. It really is easy.
If you get stuck I can help. I took pictures of every part when I disassembled mine and named them after the number in the ATSG manual for the 4L80-E.
My 80 is still going strong.
If you would prefer, drop it off here with a pair of 3" metallic catalytic converters and I'll rebuild it for you
Old Apr 19, 2006 | 11:49 PM
moregrip's Avatar
what a rush!
lol
how long did the rebuild take you?
Old Apr 20, 2006 | 12:20 AM
James B.'s Avatar
I spent a total of about 40 hours on it. That includes meticulously cleaning, identifying and photographing every single part. I could really do it much faster now, but not having ever opened an automatic transmission prior to that I wanted to make sure I knew what goes where and could not make mistakes in re-assembly. All sub-assemblies were laid out in the order they came apart. When I put it back together I checked all tollerances against the information given in the book. The unit I bought was pulled from a 2000 truck with 100k and change on it. The bushing in the forward drum was spun. The whole drum had to be replaced. I also upgraded the sprag and the overdrive roller clutch assembly to newer spec parts. Other than that it's got a rebuild kit from Level Ten Performance. All the clutches are Raybestos except the Overdrive. Raybestos wasn't making the OD clutches yet at the time. It's got a TransGo shift kit and a B&M pan. No exotic laundry list of hard parts at all! These things just WORK.
Old Apr 20, 2006 | 12:26 AM
I agree with James B. take the classes. I took the complete automotive mechanic classes at a junior college, total cost for classes was under $1500 and they were at night Monday-Friday 6-10 pm.
I went the extra step and bought a lot of the special tools, like the teflon seal installers/ resizers, four clutch piston seal installer, bushing drivers and other that I can not think of right now. I have also made a few tools, using TH400 parts, just add 1/4" rod to make a handle and you got a $100+ tool.
I have collected a few TH 400 and 4L80E trannies over the years from salvage trucks. I think the most I have spent on a tranny from the salvage yard is $200. I like going to salvage yards where they allow you to take whatever for so much money, bring a cutting torch, tools and a friend. I remember removing a 4L80E from a truck in under 15 min, the guys at the front desk where very impressed but they never asked how I did it.
If you do any type of tranny rebuild, non sponsor link even before the rebuild kit.
Old Apr 20, 2006 | 12:31 AM
How long ago did you rebuild your 80E? I built the 80E in my camaro 5 yrs. ago, and it has the Blue Plate Special in the Fourth clutch and Overrun Clutch, the rest of the clutches are for TH400 (Alto Red Eagle).
