Will a 4l60E bolt..
Old Aug 11, 2005 | 10:03 AM
BilletSilverado's Avatar
Default Will a 4l60E bolt..
Will a 4L60E bolt up to a 6.0 ok? I assume the SS trucks have 4L60's... There is not much external difference between a 60 and 80, am I correct?
Thanks
Old Aug 11, 2005 | 10:31 AM
nightmarechevy's Avatar
The SS trucks have the 4L65Es. I think the case is the exact same on both of them so it should bolt up to the 6.0 with no modifications.
Old Aug 11, 2005 | 10:32 AM
The 4L60E will bolt behind a 6.0L, but you might have to get your driveshaft resized to to fit it, depends on the legend of the tailshaft housing. The Silverado SS uses the 4L65E which is a beefer 4L60E.
Old Aug 11, 2005 | 12:08 PM
Ahh.. Thanks yall
Old Aug 11, 2005 | 01:43 PM
the 4l60 will bolt up but it is not strong enough to last very long if you raw dog your truck.
Old Aug 11, 2005 | 03:39 PM
TheChronic's Avatar
It will bolt up and then commit suicide whether you get on it or not. Just do a search and see how many guys lost their 4L60 DAYS after the 6.0 swap.
Old Aug 11, 2005 | 04:07 PM
I know that this is my second one it is just about out now. time for a 4l80e
Old Aug 11, 2005 | 07:12 PM
budhayes3's Avatar
PT's Slowest Truck
I'm pretty sure that it'll bolt up as long as the 6.0 is from 01 and up. The 99-00 6.0's won't bolt up to the 60E without some sort of modification.
Old Aug 16, 2005 | 11:26 AM
TURBHOE's Avatar
can you use the stock 4.8 tc if you use a 4.8 flywheel??
Wolftrk99
Dec 3, 2015 08:12 PM
Wolftrk99
Oct 2, 2015 08:17 AM
jamesm32
Sep 24, 2015 11:49 AM
RONIN LSX
Sep 19, 2015 05:33 PM
