Who installed their 80e Transgo HD2 without doing the pump mods?
Old Apr 11, 2016 | 02:49 PM
tgui's Avatar
Originally Posted by lxcoupe
My 2-3 is nearly identical to my 1-2 at wot. Fast and firm. What size did you guys drill your 2-3 hole to? I didn't drill 2-3, just left the check ball out per Jakes recommendation.
What checkball is that? Perhaps thats the difference here.
I have all 8 blue marked ones. Which did you leave out?
Who installed their 80e Transgo HD2 without doing the pump mods?-y9pwjmy.jpg
Old Apr 11, 2016 | 02:53 PM
lxcoupe's Avatar
4L80E / Transgo HD2 guys, what did you drill to? - LS1TECH
".108-.125 for the 2nd feed, don't drill 3rd, just leave the checkball out at that location, and .125 for 4th feed."
I honestly couldn't pinpoint which one it is on the above image.
Old Apr 11, 2016 | 03:03 PM
tgui's Avatar
Thanks! From the thread.
"I ended up rebuilding the trans, removing the HD2 separator plate, dual feeding the direct clutches internally and installed one of Jake's plates. It's back to firm shifting again with the new converter and feels great. Leaving the 3rd feed check ball out was the key to getting the 2-3 to feel good. The advice Jake gave you in the 2nd post is golden."
Old Apr 11, 2016 | 03:11 PM
lxcoupe's Avatar
I'm honored to have provided information to an 80e guru
That being said, I did drop the pan on Saturday to do a filter and fluid. Fluid looked good, no metal in the pan, magnet looked normal. I did take the opportunity to follow Jake's advice and I marked my dipstick 1/4" above the pan rail. Turns out my pan was overfilled by a solid 1/2" lol. A new filter, fresh fluid, and lowering the fluid level to what it should be did not help with temps, but strangely my 1-2 shift at low speed is less harsh, feels more normal, and my 2-3 shift even firmer at wot.
Old Apr 11, 2016 | 03:36 PM
tgui's Avatar
Don't spread lies. I know very little!
Good news on your trans!
For the records, it looks like #8 is the one being suggested to leave out.
Who installed their 80e Transgo HD2 without doing the pump mods?-rwhnrrk.gif
From here:
https://www.performancetrucks.net/fo...-506779/page6/
Slow67 knows his stuff it seems! Is the cup plug added to the case the "I like to block the 3rd accumulator" portion Slow67 talks about?
"I like to block the 3rd accumulator and leave out the 3rd checkball. Still has a controllable 2-3 shift, but still shifts firm at WOT.
When dual feeding 3rd, and drilling the bleed hole, you need a lot more fluid to fill it, and a constant supply (due to the bleed hole).
"Yes, #8 checkball."
Old Apr 11, 2016 | 03:53 PM
lxcoupe's Avatar
So you are gonna source a new separator plate and drop the valve body again? Or wait until you do clutches this summer.
Old Apr 11, 2016 | 04:06 PM
tgui's Avatar
Why would I need a new separator plate? (serious question)
I'll do clutches an all other stuff at once this summer or early fall. Gotta get other things done and I want the truck for the stormy months, not the prissy Lexus.
Old Apr 11, 2016 | 04:13 PM
lxcoupe's Avatar
If the plate has been already drilled, if you decide to also leave the checkball out, wouldn't that create an excessively harsh 2-3 shift (if that's even possible).
Old Apr 11, 2016 | 05:11 PM
tgui's Avatar
Thinking back I installed a new stock valve body plate that came with my eBay VB. But good thinking on your part. I wouldn't be worried had I modded it since my high stall absorbs some of the harsh shifts.
Sorry to steal your thread man! Oops!
Old Apr 11, 2016 | 05:47 PM
Beatdown Z's Avatar
Laid Back
I've heard there's restrictions in the 3rd gear circuit after the plate. So it wouldn't matter if the plate had been drilled or not, as long as the checkball is left out.
fillpot
Mar 1, 2016 05:51 AM
jbat35
Feb 29, 2016 10:37 AM
Mean Green z28
Feb 25, 2016 12:06 PM
rickp
Jan 26, 2016 05:00 PM
Prolong
Jan 25, 2016 12:13 PM
