what can you use in your transfer case
Old Jan 10, 2005 | 04:30 AM
Faze2183's Avatar
Default what can you use in your transfer case
i know im goin for royal purple, but im unsure of what to use, i plan to change it every 20k, and but cost isnt an issue, ive seen some use Max-Gear, Max-ATF, and then Synchromax
i dunno which to use and how hard is it to change the fluid on those puppys????
Old Jan 10, 2005 | 07:44 AM
facn8me's Avatar
I am using the royal purple atf right now. no problems so far I will put sycromax in it next time. I visited thier web site after buying. they recomend either. I run the sycromax in my 2 stroke atv gearbox with no problems also. i have the 75w90 front annd rear. 1 plug drains the transfer case the other fills it. Word of advice make sure the fill plug comes out first then pull the drain plug.
Old Jan 10, 2005 | 02:08 PM
Faze2183's Avatar
what color is the sycromax? and you think 20 to 30 k changes are good?
Old Jan 10, 2005 | 03:04 PM
facn8me's Avatar
it's all purple. And yes 20-30k is just fine. Now this is assuming you do not have the auto trac that takes a special blue fluid from GM. It is a must with auto trac.
Old Jan 10, 2005 | 04:25 PM
900Z1's Avatar
Is the dealer the only place I can get Auto Trac fluid ?
Old Jan 10, 2005 | 11:24 PM
Faze2183's Avatar
oh crap ya mine does have auto trac so do i need to go get it from the dealer?
Old Jan 10, 2005 | 11:37 PM
facn8me's Avatar
Yes I would "strongly " suggest the auto trac "blue" synthetic GM fluid. I know of no other place to find it other than dealer. I have heard it's around $6 a quart(don't quote me)
Old Jan 11, 2005 | 06:33 PM
KeukaZ71's Avatar
i've just used ATF fluid (dexron III) just like i did in the Tranny
Old Jan 12, 2005 | 11:03 AM
Faze2183's Avatar
oh ok as long if its not some like 25 dollars a bottle lol then im fine, uhhh can you use that auto trac in ur transmission?
Old Jan 12, 2005 | 12:18 PM
facn8me's Avatar
No it doesn't work in the tranny.
