vibration
Old Oct 7, 2012 | 11:24 PM
blackedoutchevy22's Avatar
Default vibration
Okay i just discovered this problem today. I was driving to Baton rouge and i was going about 75mph and i decided to get on it and around the speed of 90-100 there was this really bad vibration that almost shook the entire truck. i tried it again and it did the same thing. anybody have any suggestions im thinking it may be the driveshaft or the transmission but idk what could of caused it. it drives fine around the city i can get on it and nothing happens.
Old Oct 7, 2012 | 11:47 PM
SLCviaAK's Avatar
Driveshaft.
Old Oct 8, 2012 | 12:04 AM
you thinnk thats it i though it was that too. do they just get unbalanced or what?
Old Oct 8, 2012 | 02:21 AM
texasglock23's Avatar
possibly due to the drop. NBS or NNBS?
Old Oct 8, 2012 | 12:33 PM
its a NNBS but its been dropped for like 3 years now and i had no problems since unitl now.
Old Oct 8, 2012 | 12:43 PM
VegasJ's Avatar
lucky.
mine still vibrates at 50
Old Oct 8, 2012 | 12:52 PM
but this is a vicious vibration to where it sounds like the driveshaft is about to fly out lol
Old Oct 8, 2012 | 05:02 PM
Robert91RS's Avatar
That's because it is. If you do it again you risk alot of damage.
You need to get the shaft replaced or at least high speed balanced and you probably need some shims to correct the pinion angle.
Old Oct 8, 2012 | 06:24 PM
DR132's Avatar
what he said. the carnage a speed related driveshaft failure causes is often very extensive.
Old Oct 8, 2012 | 10:51 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Drive shaft is a strong possibility especially if your angles are not correct.
