Truetrac for front AND rear?
Old Mar 2, 2009 | 05:49 AM
texas1964's Avatar
Thanks guys. I'll get the rear done soon.
Old Mar 24, 2009 | 09:03 AM
texas1964's Avatar
Well, the truetrac is going in today. I cant wait to give it a try. I think the next step will probably be caltracs, before I get to the centerlines and slightly wider rear tires.
Old Mar 24, 2009 | 05:37 PM
BlownHD's Avatar
One or two companies makes traction aids for the 7.25" front diff, and the 9.25" front diff, but not for the 8.25". The problem is, the front ifs set up is not very strong, so putting a locker up front will usually lead to a catastrophic failure out on the trail, which is generally worse than having to winch through a difficult section.
Also for the most part if you are worried about smoking 4 tires instead of 3 you are probably in the hp range that a properly set up chassis in 2wd will give you a better 60' than 4wd.
Old Mar 24, 2009 | 05:57 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
What he said ^^
No lockers in our front diffs hence a lot of off-road guys do single axle swaps.
Old Mar 24, 2009 | 08:00 PM
texas1964's Avatar
Thanks guys. I've given up on the front diff, after reading your comments here.
I am just putting in the rear diff, and I am only using this on pavement.
I was a bit frustrated during the winter when I couldnt get much traction. I have to wait one more day to take the truck out. Patience is NOT my strong suit.
Old Mar 25, 2009 | 08:22 PM
texas1964's Avatar
Truetrac is finally in (the rear!). Driving conditions were a bit wet today, but it felt a lot better. I am squealing both tires now and will probably be looking at caltracs for my next mod. one step at a time, i guess.
5.3Okasai
Mar 9, 2022 01:07 PM
Steve-O-08
Apr 19, 2018 09:32 AM
thewrx
Aug 12, 2015 08:28 PM
vmaxpro
Aug 8, 2015 10:49 PM
vipergtrdj
Aug 6, 2015 10:19 PM
