tru-cool . .. . .cooler*
Old Mar 12, 2009 | 01:06 AM
lucky77's Avatar
Banned
Default tru-cool . .. . .cooler*
got my cooler today. . .. any-b running this cooler .? any problems with the pipes?
Old Mar 12, 2009 | 01:17 AM
viciousknid's Avatar
Where's the Beef?
If my internet is working when I get home I'll post up some pics for you. I installed mine the other day.
Was running at 200-220 degrees. Monitored for a little today on my way to work and saw a max of 137.
Old Mar 12, 2009 | 02:08 AM
lucky77's Avatar
Banned
bad **** thanks. for the info . . .
Old Mar 12, 2009 | 03:10 AM
James B.'s Avatar
That's a stacked plate type cooler. They are efficient, it should work great.
Old Mar 12, 2009 | 08:41 AM
Where's the Beef?
Here's a pic of how I mounted it. Drilled 2 holes for the 2 top screws and removed the lower bracket and used hardware supplied and factory bolts for the lower.
Yours is NNBS so i'ts probably a bit different.
You'll see a spot on the passenger side to run the hoses. I ran mine through the radiator and then the cooler.
I consider it more efficient that way and it's easier to hook up because your only messing with 1 line. The bottom line on the radiator should be the one you'll want to unhook and use.
If you drill like i did. the aluminum is VERY easy to drill into, so don't apply any pressure. just let the bit do the work. You don't want to punch through and damage your condenser.
Old Mar 12, 2009 | 11:19 AM
MeanZ71's Avatar
I like mine, and like Josh said be careful with the condenser it's very easy to damage when installing
Old Mar 12, 2009 | 12:19 PM
00ChevyScott's Avatar
Wearin' da big hat
I love mine also.
Old Mar 12, 2009 | 12:27 PM
shupe's Avatar
What model is that? GVW rating? Need to add one soon, temps havent risen above 160, that was with 80 deg amb.
Old Mar 12, 2009 | 12:32 PM
cwalker2006's Avatar
i have that same one.. i ghetto rigged mine hooking up the lines though. just havent fixed it because it does not leak. i painted it black and its mounted almost the exact same way as viscious kind. that lower bracket you removed, did it have a sensor on it?
Old Mar 12, 2009 | 12:36 PM
lucky77's Avatar
Banned
how many coats of paint did u spray < what paint did u use?
