THE Tru-Cool 40K GVW Transmission Cooler Install Thread
Old Sep 26, 2015 | 09:10 PM
  #251
Wolftrk99's Avatar
Originally Posted by tgui
Nice!!! I have all the parts in a box ready for my swap
Word of advice put trans in place and if youre running new factory cooler lines, slide em past oil pan and wiggle em in from the rear.... Makes live much easier than tryin go the other way...... Especially if you have a warn hidden winch mount!!!
Old Sep 27, 2015 | 05:35 PM
  #252
bruceb58's Avatar
Default Just Installed Mine
1999 Silverado 1/2T
Did not come with the small cooler in front of the radiator.
I routed the output of the radiator cooler to the Tru-Cool. I made a new line that went from the exit of th Tru-Cool back to the transmission.
I used a straight piece of aluminum bar with some spacers at the top and I flipped and rotated the bottom support bracket with a couple holes for the bottom mounts.
All went well except for accidentally drilling into the AC condenser!
I went with Earl's fittings since it sounds like they have less issues.
Old Oct 8, 2015 | 01:31 PM
  #253
06_crewcab_ss's Avatar
Originally Posted by bruceb58
1999 Silverado 1/2T
What size fitting did you use going to the rad? I'm looking to switch mine over to all AN line soon
Old Oct 8, 2015 | 01:36 PM
  #254
bruceb58's Avatar
Same as what goes to the Tru-Cool.
Earl's Performance AN to Inverted Flare Adapter Fittings 991947ERL - Free Shipping on Orders Over $99 at Summit Racing
Old Oct 8, 2015 | 01:40 PM
  #255
Cool thanks! I thought that's what it was but wanted to be sure before I ordered anything
Old Nov 4, 2015 | 10:47 PM
  #256
ClintBeastwood's Avatar
Default 2013 escalade install
I used the Napa fittings on the install. Took the whole bumper off. Removed the stock cooler. Took out a plastic tray that goes between the radiator and bumper brace to free up the lines. They turn to rubber underneath so there's lots of give. Mounted the cooler with the metal universal brackets the kit comes with. Probably sticks out 1.5" out from the radiator brace. The driver side line popped right in. Passenger side was tight but went in with some persuasion. Had to trim some of the styrofoam on the inside of the bumper cover to clear the lines. The cooler was installed without cutting the factory lines at all. Direct plug and play. I saw a similar install was done on a 2013 silverado here that's what I used for reference. The newer nnbs trucks will most likely not require any cutting of the lines at all with the Napa fittings!
Old Nov 4, 2015 | 11:05 PM
  #257
Wolftrk99's Avatar
Didnt have to cut my line on my 99 either....
Old Nov 6, 2015 | 09:11 PM
  #258
tgui's Avatar
Stupid question, should I use Teflon when threading things on?
Old Nov 6, 2015 | 09:32 PM
  #259
Atomic's Avatar
I have a gauge for that
NPT fittings yea, flare fittings no.
Old Nov 7, 2015 | 12:54 AM
  #260
OHsixLS3's Avatar
So what type of fitting is used to connect to the Tru cool itself? AN fitting?
