transgo and servo install...
Im going to be installing transgo hd2 shift kit and corvette servo today...Is there anything i should know befor intalling any tips? also how much trans oil will i need to put back in and what kind?
Do not use more than ONE washer!
My 4L60E's first gear just went bye-bye less than an hour ago (story behind that
). Using ONE washer in the 1-2 accumulator should be plenty. Two washers will give you a nice, chirpy 1-2 shift, but I think a 2-1 downshift is extremely detrimental with two or more (ask me how I know). Instructions are simple. Take your time, and you'll be fine.
Shouldn't take more than a day to get it done... give yourself more than one day if you haven't done this before (start to finish).
). Using ONE washer in the 1-2 accumulator should be plenty. Two washers will give you a nice, chirpy 1-2 shift, but I think a 2-1 downshift is extremely detrimental with two or more (ask me how I know). Instructions are simple. Take your time, and you'll be fine. Shouldn't take more than a day to get it done... give yourself more than one day if you haven't done this before (start to finish).
Just some Dexron III ATF will do... aint that the name of the suff???
My mind has gone blank.....
Im guessing your doin a filter change while your at it??
5qts should get you back close to full... so get 6qts..
Oakay so if i do the shift kit also i will need 6 quarts? Do i have to use Dextron 3...ill be hopefully doing it tommarrow so i wont have a chevy dealer open..only like a walmart..
