transgo and servo install...
Old May 19, 2007 | 09:38 AM
UBLUZIN03's Avatar
Default transgo and servo install...
Im going to be installing transgo hd2 shift kit and corvette servo today...Is there anything i should know befor intalling any tips? also how much trans oil will i need to put back in and what kind?
Old May 19, 2007 | 12:10 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Do not use more than ONE washer!
My 4L60E's first gear just went bye-bye less than an hour ago (story behind that ). Using ONE washer in the 1-2 accumulator should be plenty. Two washers will give you a nice, chirpy 1-2 shift, but I think a 2-1 downshift is extremely detrimental with two or more (ask me how I know). Instructions are simple. Take your time, and you'll be fine.
Shouldn't take more than a day to get it done... give yourself more than one day if you haven't done this before (start to finish).
Old May 19, 2007 | 05:05 PM
UBLUZIN03's Avatar
Does it matter what kind of ATF i put back in or does it have to be gm dextron or whatever it is?...
Old May 19, 2007 | 06:14 PM
nonnieselman's Avatar
Just some Dexron III ATF will do... aint that the name of the suff???
My mind has gone blank.....
Im guessing your doin a filter change while your at it??
5qts should get you back close to full... so get 6qts..
Old May 19, 2007 | 06:45 PM
UBLUZIN03's Avatar
I wasnt planning on doing a filter change..I read you only lose like 1qt of oil?
Old May 19, 2007 | 07:20 PM
bluecajun5.3's Avatar
11 Second Truck Club
1qt of fluid is only for the servo.
listen to nonnie
Old May 19, 2007 | 08:12 PM
UBLUZIN03's Avatar
Oakay so if i do the shift kit also i will need 6 quarts? Do i have to use Dextron 3...ill be hopefully doing it tommarrow so i wont have a chevy dealer open..only like a walmart..
Old May 19, 2007 | 08:43 PM
95ImpSS's Avatar
You can get the Dex fluid from any parts store (or Wally World). It doesn't have to have a GM logo on the bottle. Six (6) quarts should do if the TC's full. I was pretty close with six. Look at the fluid to see that there are no metal shavings or anything to deal with. As long as the fluid is a transparent color of red (not dark red), then you're good to go. You can get the trans pan gasket & filter fairly cheap. Why use the same filter? You are planning on replacing the gasket, right?
Old May 19, 2007 | 08:54 PM
UBLUZIN03's Avatar
The shift kit came with new a new pan gasket..i probley wont change the filter cause my gm dealer/napa whatever isnt open on sunday..
Old May 19, 2007 | 09:10 PM
95ImpSS's Avatar
eyyyokay.
