tranny issue, need some help.
Old Nov 24, 2013 | 08:58 PM
Tig's Avatar
Tig
In the Arctic? Where about?
Now I need to find a reputable tranny shop, being new to the area and not knowing many people, this could be hard. Family is coming down Tuesday to, not a good time for this mess.
I'll ask around tomorrow to see if I can find any local reputable shops.
Thanks for the info Koots, I appreciate it.
Old Nov 25, 2013 | 11:59 AM
Koots's Avatar
In that case, get it scanned first for free at Autozone/Advanced, then go from there. if it does need servicing, I would then take it to a reputable transmission shop. Just call around and see if you can find one that seems knowledgeable enough about modern automatic transmissions.
It might not be the TC after all, as I get a vibration right now when my truck goes into lockup but that's because of a wobbly rear output bearing on my t-case that needs a rebuild soon. It will eventually destroy the rest of my drivetrain if left alone
Old Nov 25, 2013 | 06:49 PM
01silvy's Avatar
mine was doing the exact same thing before the TC gave up completely and let its guts go through the rest of the tranny. it would shutter until I let off the throttle or made it downshift. Hope you get it figured out quick
Old Nov 26, 2013 | 04:50 PM
Tig's Avatar
Tig
Thanks Koots, I'll be heading over to AutoZone tomorrow late morning for them to scan it.
01,
Thanks man I appreciate it.
Hopefully I'll catch it before any damage is done.
I don't live too far from you, I'm over in Raleigh
Old Dec 2, 2013 | 07:19 PM
Tig's Avatar
Tig
Made it to AutoZone.
I'm not sure if it needs a CEL for it to acknowledge an issue but, nothing came up.
Does anyone have an idea of what it costs a tranny shop to hook it up to the computer to diagnose what the problem could be?
Thanks
Old Dec 2, 2013 | 08:45 PM
chevrolet all the way's Avatar
you need a real scanner hooked up. I run a trans shop and get these all the time. You could be looking at a developing misfire. The load when your truck goes into lockup will cause a light miss that will not show up as a code or during any other time. Any person who knows how to properly use a good scanner can check for a misfire over a converter shutter.
Converter shutter can happen, but its not nearly as common as the misfire.
Old Dec 3, 2013 | 06:16 PM
Tig's Avatar
Tig
Now that you bring that up. When I am idling I get a small roughness in my idle.
I was thinking about a miss but didn't realize this could cause a problem at speeds.
Will a scanners pick up where the miss is coming from even though there is no code?
Thanks
Old Dec 3, 2013 | 06:27 PM
Originally Posted by 1969x11
Misfiring? Does it ever throw any codes?
Pull the plugs and give them a look see. You probably have a bad one.
Old Dec 3, 2013 | 07:27 PM
Tig's Avatar
Tig
It doesn't or hasn't thrown any codes.
I'll have to pull them this weekend and check them out.
Thanks
Old Dec 3, 2013 | 10:26 PM
yes it has to miss a certain amount before a code will be set. Wires have been known to break down premature in 07 up trucks around here. most scanners have a misfire counter you can watch that shows each cylinder individually. On some i had to dig a little deeper to see it, but that usually will show all you need!
