tranny issue, need some help.
#91
There might be some real minor slop in the actual slip yoke were it goes into the rear of the trans but the Joints should be solid.
#92
#95
Both joints are solid, front and rear.
Yes, you are correct it is a one piece aluminum drive shaft.
I wonder if the tail shaft is damaged.
I wish I could get a good video of the actual noise it makes when driving.
#96
Well, I had spoken with the owner of the converter company. Cool guy, very helpful.
From the explanation I had given him. He said that it is going to be one of two things, either the converter or a misfire. I just changed my plugs and wires.
It has a slight hiccup at idle and the tuner at RPM picked up several misfires while we were doing a road tune. Its pretty much been like that since I bought it. And since it doesn't throw any codes, not one tech has even attempted to try to resolve this. All I hear is, if it doesn't throw a code, we cant see anything.
Now, how the hell do I figure out exactly where this misfire is coming from?
This was something I had brought up with the original shop, his answer was "its old".
Misdiagnosis and a ton of money down the drain.
#97
I had e-mailed RPMs tuner to see if he could clarify which cylinders were misfiring. He had only mentioned cylinder 3 when I was there.
This was his response "All of them. The dod cylinders had higher counts then the rest though."
Should I start to worry now?
Thoughts opinions are more than welcome.
Driving home today the shudder was as it was before I had any work done to it. Very slight.
#98
I didn't realise you had a DOD set up. Is it actually throwing any misfire codes??? Such as P0300
#99
This is the converter. 2800/3000 9.5" billet lock up converter.
LS SERIES ENGINES, 4L60E, 4L65E - 2800-3000 STALL - FTI Performance
That's what's throwing me for a loop, no codes.
I should've stated that on the first page about having DOD.
I thought all 07+ Trucks/SUVs had DOD.
#100
Most likely a case learn would also help the computer learn the senor error with the new stall.
I would have to think a good tuner would be able to make some small adjustments and be able to identify if it's a mechanical issue or a tune related issue.
I wish I could be of more help but this is the type of problem that has to be examined first hand.
