Torsion Bar Adjustment Uneven
I recently finished installing upper and lower DJM lowering a-arms on my Z71 and the bolts on the adjusters are not even. One is right in the middle of the adjustment and the other is backed almost all the way out. These are stock keys.
What would cause this? I don't remember them being this bad before installing the DJM arms. Any ideas?
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
100% typical, I never seen a truck that sat level and the bolts were turned in the same on both sides, the metal used isnt a perfect density all the way through, so it takes a slightly different amount of twist to get the same amount of downwards torque. But if yours are off that much is possible you didnt put the key in the right orientation, probably the one that has the bolt all the way in
Mine is the opposite. Drivers side is most the way out and passenger side is 1/2 way in. I am debating whether or not to put the lowering key in on the drivers side.
Do you know if the bars are side specific?
It would be very hard to put the keys in the wrong orientation. Its not a big deal if theyre different thats how i always see them. If the bolts are even then the truck doesnt sit level.
carid
Oct 1, 2015 09:22 AM
