Torque Converter Install Issues
Old 03-28-2015, 04:59 PM
Registered User
DO-WORK-SON's Avatar
Default Torque Converter Install Issues
This is now the second torque converter I've bought and tried to install, only to find out its about 3/4 of an inch to long, I'm pretty certain i have a 4l60e and 5.3 both out of a 2002 tahoe, they were swapped into the truck by the previous owner, i'm just trying to install a stall converter and this is really starting to **** me off, what am i not getting here?
Attached Thumbnails Torque Converter Install Issues-1926126_718040114979963_1305923391047161197_o.jpg   Torque Converter Install Issues-10495105_718042331646408_5226961191972625199_o.jpg   Torque Converter Install Issues-10986497_718042114979763_8192774586388644316_o.jpg
Old 03-28-2015, 09:44 PM
shupe's Avatar
Not sure man. Don't recall either of my trucks with 4l60 ('99 or '08) converters not having a flush nose. Can you snap a picture of the passenger side of the trans and a pic of the flexplate?
Old 03-28-2015, 10:13 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Does the transmission have a removable bell housing????
I'm going to venture out and say they left the original trans in and only swapped the motor.
Old 03-28-2015, 10:29 PM
Registered User
hemi-fi's Avatar
I believe you need the torque converter for the 1996 one piece 4l60E trans your using with your 5.3 engine.
Old 03-28-2015, 11:33 PM
GMCSIERRA5.3's Avatar
The blue converter is for 93-98 models..the one on the right is the one your going to use fits 99+ 4l60s
Old 03-30-2015, 07:12 PM
Registered User
thanks for all the replies, yes i have a one piece trans case, was not aware this was even a thing before ordering, tried explaining my issue i had with another converter i bought to Circle D when i was ordering this one to ensure this didn't happen a second time but here we are. I bought this truck with the swap already done so i assumed the trans was also out of a 2002 Tahoe like the motor, i was wrong.
Old 03-31-2015, 09:30 AM
Former Vendor
Circle-D's Avatar
Sounds like you have the original trans still, what we call a 4L60 LT model. We can custom make you a converter that will fit the earlier transmission and bolt to a LS motor. We can do it in our HP series in about a 2500 stall with the 298mm option. Or we can do it in any stall range with our Pro series. You can send in the 278mm converter and use it for credit towards the new one. Sorry for all the confusion....
Chris
Old 07-15-2020, 04:35 PM
Registered User
Rschafer56's Avatar
Default 2005 gmc sierra 5.3 and 4l60e
Chris
i feel like im having the same issue I believe i have the wrong torque converter as well it doesnt fit as it should
LCHEE
10-24-2020 04:10 PM
TAPyvehc93
07-23-2017 10:54 PM
BennyB
08-01-2015 08:48 AM
KyleW707
07-29-2015 08:17 AM
JordanH
07-14-2015 03:46 PM
Quick Reply: Torque Converter Install Issues
