suburban big brakes.....
Old Jan 10, 2008 | 01:30 PM
53bowtie's Avatar
Default suburban big brakes.....
did brakes all the way around on a suburban the other day and noticed it had dual piston calipers, same size, front and rear.....
rotors looked the same as on my 02 truck so i was wandering if switching to suburban brakes would help me stop me and my dads boat any better? i am sure i can find some at salvage so it seems a cheep upgrade that i dont have to go aftermarket to get better stoping....thanks for the replies!!
Old Jan 10, 2008 | 03:59 PM
02BlueStepside's Avatar
If I am not mistaken, Scream did the 2 piston conversion on the rear of his truck. I think you also need the rotor as something was different.
Old Jan 10, 2008 | 11:28 PM
53bowtie's Avatar
cool, thanks for the reply. anyone know whats different??? do i need the rear rotors as well? it seemed to me that the emergency break stuff was all the same LOOKING i dont know about working....
Old Jan 11, 2008 | 01:01 AM
Faze2183's Avatar
I think if I recall my rear brakes had dual pistons...
Old Jan 11, 2008 | 08:40 PM
53bowtie's Avatar
mine are single piston.....i was thinking of swaping to the duals in the back and poss. a hydro-boost setup, a solid braking foundation for future engine mods that will have less than optimal vacuume...and it is all "stock" equipment....
Old Jan 11, 2008 | 08:56 PM
supersub's Avatar
the e-brake shoes are dif!I would recomend just going with baer +1 eradispeeds.they Really work
Old Jan 11, 2008 | 08:59 PM
53bowtie's Avatar
cool, thats what i needed to know thanks!
Old Jan 13, 2008 | 08:54 AM
built408's Avatar
Ive done a suburban brake swap on the rear of myn... Helps out alot.... You need the calipers, rotors (alot thicker and disipate the heat better), and the caliper brackets. The e-brake shoes are the same. Thats it...
Old Jan 13, 2008 | 11:55 AM
skyhighsami's Avatar
no title here
What about to put them on a truck that came with rear drums? Will the master cylinder withstand it?
Old Jan 13, 2008 | 11:25 PM
53bowtie's Avatar
i was thinking the e-brake looked the same as my truck. thanks for the reply, maybe i will end up doing this after all.....
and also like stated above was the master cylinder able to handle the extra 2 pistons ok??
calsdad
Jun 14, 2023 11:07 PM
cheyenne383
Nov 13, 2015 09:24 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
The_W
Oct 1, 2015 02:35 PM
