Stupid $!%!##@ rear transmission seal
Old Mar 21, 2009 | 12:40 AM
StrokerAce03's Avatar
Default Stupid $!%!##@ rear transmission seal
Ok; so the rear seal where the slip yoke goes into the tailshaft is leaking on my truck. I got a new seal and now I can't figure out how to get the old one out.
I tried prying it out but I'd be prying against the output shaft and don't know if that's ok or not? The output shaft moved a little when I tried it earlier so I didn't want to chance it. I also can't get a screwdriver behind the outer ring so I'm at a loss.
Any suggestions?
Old Mar 21, 2009 | 01:15 AM
CashDudeHomie's Avatar
If you can't get a screwdriver wedged in from the outside, try putting the tip of the driver against the outside edge and tapping it with a hammer to bend the seal inward. Then it should be easy to grab with plyers or something.
Old Mar 21, 2009 | 09:06 AM
venomhp's Avatar
or an angles flathead can do the trick
Old Mar 21, 2009 | 11:34 AM
Like a small prybar? I'll try tapping on it after work today and see what it does. How fragile is the case? I mean, I won't be beating the **** out of it or anything but I just wanted to be sure.
Old Mar 21, 2009 | 09:33 PM
oldred95's Avatar
I take a wood chisel and a hammer and cave one side of the seal in which loosens it up in the transmission case. Then grab it with vise grips and pull it right out. Takes a minute or two at the most.
Old Mar 21, 2009 | 09:41 PM
budhayes3's Avatar
PT's Slowest Truck
Do you have a slide-hammer with a hook on the end? That would work, if not I'd go with oldred95's suggestion.
Old Mar 22, 2009 | 12:36 AM
I don't have a slide hammer but I'm gonna try oldred95's suggestion tomorrow. I just gotta put it in the air because its so damn low; I can't get under it even on ramps
Old Mar 22, 2009 | 12:49 AM
That's the same thing I suggested in the first reply, just with a screwdriver instead of a chizel
It will come out easy once you get under there.
Then you will need a large socket or piece of pipe the appropriate diameter to properly drive the new seal into place.
Good luck man.
Old Mar 22, 2009 | 04:05 AM
cheyenne383's Avatar
TOWN CRIER
How far from Atlanta are you? I can swing by and give you a hand if you need it, PM me if you can't get it, I've done a bunch of them.
Old Mar 22, 2009 | 04:19 AM
Good luck man.
I know dude and thanks; he was just the last one mentioned. Some sort of sharp flat object then
I'm in Macon; I'll look at it in a few hours when its daylight.
