Stock converters
Old May 6, 2006 | 12:37 PM
ChiScouter's Avatar
Default Stock converters
I have 2 converters to choose from, one from a 99 5.3, and one from a 02 camaro ls1. Which would be the better choice behind a 02 ls1 and the 99 4l60E in a 4200 lb 4x4 with 4.56 and 35 inch tires that will be a daily driver
Old May 7, 2006 | 01:32 AM
5.3 probably... but im no expert
Old May 7, 2006 | 02:16 AM
three83's Avatar
I'd go with the one from the 99 5.3.
Old May 7, 2006 | 07:37 AM
CoonToot's Avatar
I don't think the LS1 version will fit a NBS truck...there are a few differences between the truck version and the f-body version. Check to make sure whatever you buy is 100% compatible.
Old May 7, 2006 | 10:50 PM
ChiScouter's Avatar
Thanks guys I already have both converters, Ill take a close look at what may be different between the 2. I also have a complete ls1, and a complete 5.3 that I will be mixing parts between to get one engine set up the way I want. The trans is from the 5.3.
If it turns out that I can physically use either converter than I am wondering if the converters have different stall speeds, and if one may be more rugged inside than the other
Old May 8, 2006 | 11:26 AM
Quik's Avatar
5 year bitches!
use the 5.3 it should stall alittle better behind a ls1. also depending on the year of the tranny and what not that depends if hte ls1 converter will work.
LCHEE
Oct 24, 2020 04:10 PM
greedygenius
Sep 3, 2015 06:51 AM
OLD BULL
Aug 1, 2015 05:00 PM
GMCtrk
Jul 17, 2015 06:39 PM
black6spdz
Jul 16, 2015 01:32 AM
