Spacing out stock wheels?
Old Oct 10, 2005 | 03:46 PM
TG02Z71's Avatar
Default Spacing out stock wheels?
Can it be done? How much can you get away with?
I can make any thickness spacer so getting them is not a problem.
I thought maybe pushing them out a half inch or a little less than that would give slightly better handling.
If I'm talking out my *** let me know!
Old Oct 10, 2005 | 05:23 PM
5.3 racer's Avatar
how much you can get away will probably depend on how far your lug nuts thread onto the studs.
Old Oct 10, 2005 | 06:18 PM
TG02Z71's Avatar
Yes, but how much is enough? that is the question.
Old Oct 10, 2005 | 06:37 PM
SBChevrolet's Avatar
thats really up to you
Old Oct 10, 2005 | 09:20 PM
SnakeOiler's Avatar
you could probably space them out 3/4" to 1", but get longer wheel studs. If you space an inch, get an inch longer wheel stud. If you space a 3/4", get 3/4" longer wheel stud.
Old Oct 12, 2005 | 06:46 PM
kitronic's Avatar
Default Wheel spacers
Been thinking about the same thing, using adapters on the narrow back axle of my 2500. They recommend kits that widen the rear 2.5 inches to match front track.
Here's a couple links to manufacturers;
http://www.wheeladapter.com/wheel_ad...el_spacers.asp
http://www.pumasales.com/product_category.asp?id=513
They're not cheap, $200-300
Old Oct 13, 2005 | 08:23 AM
TG02Z71's Avatar
I did not realize that the real axle in your truck was norrower than the front. I wonder if the 1500 series is this way too? I'll have to pull out the tape and check.
Thanks for the links, those are some serious spacers on the sites. Gives me ideas on what to make. Looks like a good winter project.
Old Oct 13, 2005 | 08:34 AM
TurboGibbs's Avatar
You would be safe with 3/8 inch or so. Any more than that and the studs become weak due to the leverage agaist them is further out. You could more easily snap the studs during heavy cornering, potholes, or accelerating with wheel hop. The only safe way to do it more than that is with the wheel adapters above that have a new stud on them.
5.3Okasai
Mar 9, 2022 01:07 PM
mzoomora
Jan 3, 2016 07:06 AM
thunder550
Oct 8, 2015 04:53 PM
vortecyota
Jul 23, 2015 08:26 PM
Ketis
Jul 23, 2015 12:37 PM
