Shifting Issue...
Old Sep 3, 2007 | 03:12 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Default Shifting Issue...
I recently purchased the 46-mod for the 4L60E trans. The first difference that I notice is that the 1-2 shift lags more than it should... meaning it happens much later than I think it should (IMO). I've gone back and readjusted shift points from 6300 to 6000 RPM. The rev limiter is set to 6500 (formerly 6600). I made a few runs earlier, and the shifting issues mellowed a bit.... but, it still seemed like the truck fell on it's face spinning the RPMs up to 6453 (past the 6000 specification). I'm wondering if I should lower the RPM shift point again, but not too sure. I'm wondering if there's a lack of vacuum.
Any suggestions?
Old Sep 3, 2007 | 03:21 PM
BlackGMC's Avatar
Resident Retard
What is your MPH shift set too? It is my understanding that both RPM and MPH have to be met inorder to shift.
Old Sep 3, 2007 | 03:28 PM
FLT's Avatar
FLT
FormerVendor
The 46mod is only controlling the transmissions line pressure. It has nothing to do with the shift timing.
Old Sep 4, 2007 | 11:11 AM
95ImpSS's Avatar
Ok... went out later yesterday evening after making some adjustments. I check the vacuum connections, and all was as it should. The alledged "late shifting" seems to have mellowed to an occasional thing. What I did notice is that there is an apparent delay with transitional shifting (downshifting @ WOT). I tried cruising at ~45mph, then going WOT to see how the response was. Well, I'm sorry to report that I can completely count off "one, one thousand" before the downshift occurs.
Now, this (in no way shape or form) does not negatively impact (nor reflect the great knowledge & customer service of) the vendor to whom I purchased this from. I am concerned with whether or not this is just the "nature of the beast" or if there's a way to correct it, how can it be done? Input is always welcomed. Thanks!
Old Sep 4, 2007 | 11:25 AM
Tootall's Avatar
Old Sep 4, 2007 | 07:48 PM
95ImpSS's Avatar
In case you haven't figured it out yet, I'm f$%&#@!@ pissed at the trans again! I hop in the truck to run to the gym to cancel membership (don't have time to go with 3 YOUNG kids). I pull out of the driveway, and immediately notice the truck's revving to high when it's supposed to be in 2nd gear @ 25mph. HPT says it's in 2nd, but RPMs are showing 3000+. WTF?!?!?! F%$#&!^@ POS is broke again. What the hell?!?! Beau, get your *** back to BR, and take Murphy's punk *** back home with ya!!!!!!!!
Before anyone posts that it may be the tune, I've flashed a different tune & even a stock tune using "Write Entire", and that was no help. Vince has asked me about the 2-4 band a week ago, and at the time, it looked normal. There's a couple of things I'm thinking of... valve body, gaskets, 1-2 accumulator (piston was kinda hard to move during installation). I'm wondering if the band slipped or broke. Trans worked fine this weekend. Today, it never worked. Help a brotha out.
Old Sep 4, 2007 | 08:40 PM
Nick™'s Avatar
I'll help you out, how about I just give you $500 for that truck
let me know when/if the time comes to pull it again, you know I have a little experience getting tranny fluid on my from working on a certain white 4X4
Old Sep 5, 2007 | 06:51 AM
95ImpSS's Avatar
That's the ONLY plus about the new trans pan... no more fluid leakage on carport with pan that has a FUNCTIONAL drain plug. You're more than welcome to swing by when I pull it. I'm not doing it this week, as I think I'd light a match to it after pouring 5 gallons of gasoline on it.
Vince... got your message. I didn't realize it until late. I wasn't ignoring you. After the truck issue, I figured I'd separate from computers, phone, etc. I know it's bad when my wife asks if it broke again, and she doesn't have a comment to offer. Anyway, I played with my 8-month old for a long while trying to get him to walk. He took his first solo steps over a week ago, and took several more last night. Gonna back away from truck for another day or so. I'll give ya a ring later today.
Old Sep 5, 2007 | 09:09 AM
Tootall's Avatar
sounds like a valve body gasket
or a vac leak
Old Sep 6, 2007 | 05:48 AM
95ImpSS's Avatar
or a vac leak
I'll whip out the jack stands today or tomorrow, and drain the fluid. Will pull the panto see if the tube was really snug as I thought. If that's cool, I'll look at the valve body.
