Shifting Issue...
formerly 1BADC10 (12/14/2011)
I recently purchased the 46-mod for the 4L60E trans. The first difference that I notice is that the 1-2 shift lags more than it should... meaning it happens much later than I think it should (IMO). I've gone back and readjusted shift points from 6300 to 6000 RPM. The rev limiter is set to 6500 (formerly 6600). I made a few runs earlier, and the shifting issues mellowed a bit.... but, it still seemed like the truck fell on it's face spinning the RPMs up to 6453 (past the 6000 specification). I'm wondering if I should lower the RPM shift point again, but not too sure. I'm wondering if there's a lack of vacuum.
Any suggestions?
Any suggestions?
Ok... went out later yesterday evening after making some adjustments. I check the vacuum connections, and all was as it should. The alledged "late shifting" seems to have mellowed to an occasional thing. What I did notice is that there is an apparent delay with transitional shifting (downshifting @ WOT). I tried cruising at ~45mph, then going WOT to see how the response was. Well, I'm sorry to report that I can completely count off "one, one thousand" before the downshift occurs.
Now, this (in no way shape or form) does not negatively impact (nor reflect the great knowledge & customer service of) the vendor to whom I purchased this from.
I am concerned with whether or not this is just the "nature of the beast" or if there's a way to correct it, how can it be done? Input is always welcomed. Thanks!
In case you haven't figured it out yet, I'm f$%&#@!@ pissed at the trans again!
I hop in the truck to run to the gym to cancel membership (don't have time to go with 3 YOUNG kids). I pull out of the driveway, and immediately notice the truck's revving to high when it's supposed to be in 2nd gear @ 25mph. HPT says it's in 2nd, but RPMs are showing 3000+. WTF?!?!?! F%$#&!^@ POS is broke again. What the hell?!?! Beau, get your *** back to BR, and take Murphy's punk *** back home with ya!!!!!!!!
Before anyone posts that it may be the tune, I've flashed a different tune & even a stock tune using "Write Entire", and that was no help. Vince has asked me about the 2-4 band a week ago, and at the time, it looked normal. There's a couple of things I'm thinking of... valve body, gaskets, 1-2 accumulator (piston was kinda hard to move during installation). I'm wondering if the band slipped or broke. Trans worked fine this weekend. Today, it never worked. Help a brotha out.
I'll help you out, how about I just give you $500 for that truck
let me know when/if the time comes to pull it again, you know I have a little experience getting tranny fluid on my from working on a certain white 4X4
You're more than welcome to swing by when I pull it. I'm not doing it this week, as I think I'd light a match to it after pouring 5 gallons of gasoline on it.
Vince... got your message. I didn't realize it until late. I wasn't ignoring you.
Originally Posted by Tootall
sounds like a valve body gasket
or a vac leak
or a vac leak
