Shift Kit
Old Oct 25, 2007 | 01:53 PM
Tootall's Avatar
Originally Posted by circusboy
yank tt3000. 17K miles. Is that located outside the transmission?
it's internally, . . . . you really need to read the instructions. I'm not one for reading up on a sheet of paper with a box of springs, but you really need to read these over carefully.
Old Oct 25, 2007 | 03:49 PM
Yogi Bear's Avatar
Where do the washers go that firm up the shifts.
The spacers go into the accumulator piston, which is accessed from the side of the tranny. I believe that the spacers firm up the 2-3 shift.There are some holes that need to be drilled in the separator plate (under the valve body inside of tranny) that also go a long way toward firming up the shifts, especially the 1-2 shift..
Old Oct 25, 2007 | 06:59 PM
Wide Open's Avatar
I am not a transmission expert but I think the piece on the side is the servo not the accumulator. The accumulator is inside the transmission pan next to the valve body. You should have good pictures of the items and parts included in your instructions.
Old Oct 25, 2007 | 10:08 PM
Tootall's Avatar
there are spacers that go inside, and on the out side.
here's my pics http://s122.photobucket.com/albums/o...TransGo%20HD2/
here's your "washer spacer"
Old Oct 26, 2007 | 03:41 PM
Yogi Bear's Avatar
I had it wrong. The spacer goes into the accumulator (in Tootall's picture) which is inside the oil pan. Stiffer springs in the kit go in the servo which is on the passenger side of the tranny.
Oobray
Jun 13, 2022 03:38 AM
Blackrat48
Aug 16, 2015 11:56 AM
lycominghunter
Aug 15, 2015 12:26 PM
Ammadien
Jul 22, 2015 08:50 PM
zaathur151
Jul 6, 2015 10:57 PM
