Sent my 4L60E to TransBuilderGuy
Old Jul 13, 2018 | 05:50 PM
  #211
darkirish63's Avatar
Originally Posted by 2001 Sierra
I'll give ya that if your all blown and/ or tuboed- but behind a swapped in stock LQ9 at 5000+ ft the 4L60 should live...………..
True but I've killed two "built" 60e's behind two different stroker motors. The shear weight combined with the torque of a stroker killed them. The HP really isn't an issue.
Old Jul 13, 2018 | 06:16 PM
  #212
tgui's Avatar
Well don't the 60es have issues worth the 4-2 shift and things blowing up regardless of weight?
That said I'm no pro but I've been through both and the 80es are just beefier. Plus the 80es only use a band for reverse of I'm remembering correctly.
Old Jul 14, 2018 | 07:43 AM
  #213
madmann26's Avatar
Yes the 4-2 shift is a no no.
I've tried to make a 60e live behind my 500 crank lq9 and it just can't.
I had it out/rebuilt 3-4 times and had I just cut my losses after the first failure, I would've save a bunch of money.
Lesson learned. I've had the 80e in since Feb and it's finally stable.
I can get in it and drive it without worry. When I had it rebuilt, I had the guy do the internal dual feed.
The only thing you have to be careful about in 80e is the sprag. If you play, do it in manual d3.
Old Jul 14, 2018 | 09:52 AM
  #214
Mark Johnson's Avatar
Sure is fund though, eh? But really- for you all out racing folk the 80 is a necessity. Around 394 HP is all I'm looking at...……..
Old Jul 14, 2018 | 10:22 AM
  #215
turboal1's Avatar
Default 60e
Iv'e been running a 60E behind my 6.2 for
over a year, 400/400 with no prob. it was
just tuned with the eng on the dyno/street.
granted i am lighter than your trucks. so
this helps a lot i guess. I run it hard but
don't abuse it.
Old Jul 14, 2018 | 03:54 PM
  #216
madmann26's Avatar
Very fun. I did it a few times on my original 5.3 with LTs and cam.
That's not what broke it.
What broke it was a 3/4 throttle take off getting on 85s one morning.
Blipped the throttle, it stalled, laid down about 50ft of rubber and then nothing. No noise, just nothing. Lol
And weight plays a big part in the life of a 60e.
Old Jul 14, 2018 | 06:22 PM
  #217
When the junk flies apart will be the telling moment...…...
Old Aug 17, 2018 | 07:01 PM
  #218
kuntryquest's Avatar
Took the truck to a local transmission shop, he has a few ideas. Better than shipping it back to Florida for how ever long
Old Aug 18, 2018 | 03:32 PM
  #219
Swap time...save yourself from goirmg back again and again with a 60e.
Old Sep 6, 2018 | 06:59 PM
  #220
Update - trans shop checked the valving, electrical, replaced TCC again. used scanner to command lock up when cold, truck stalls. Once warm the surge is there, pulled the trans and converter and sent it out to precision industries. clutches are burnt up. Still under the free refresh program so I just have to pay shipping. The Billet rotor had some marks in it from who knows what so the trans shop will take them out.
