replacement wheel stud knurl diameter?
Old Jul 2, 2015 | 11:10 AM
zblee's Avatar
Default replacement wheel stud knurl diameter?
I have a 2003 silverado 5.3l RCSB and I need to replace several of the wheel studs on my rear as they have been snapped off by the previous owner. I believe that i need to get some 14mm X 1.5 studs but I see different knurl diameters and not sure which to get , they range 16.00mm +/- .25 or so ... any idea which ones fit factory ? are the larger diameter just a tighter fit vs the smaller diameter, but will both fit?
thanks
_zblee
Old Jul 2, 2015 | 12:04 PM
whytry85's Avatar
stock knurl size for 1/2 tons are .623. 610-428 is the dorman number for stock replacements. you could use the .630 but they are about 21mm shorter than the others...
Old Jul 2, 2015 | 12:17 PM
zblee's Avatar
OK thank you! yeah those were the two that I was not sure which one I needed. Couldn't find anything online that told me the difference . thanks again!
_zblee
Old Jul 17, 2015 | 11:40 AM
zblee's Avatar
So napa had two stud sizes. they had one for the front and one for the rear, the front were the longer version and the rear being the shorter. I bought both and before installing either I measured the length of the existing ones and found the rear to be the shorter of the two. based on that I ended up installing the shorter version and it installed with ease .
ss454327
Oct 17, 2015 03:43 PM
thunder550
Oct 8, 2015 04:53 PM
bsn1989
Jul 16, 2015 08:20 AM
mrgrim
Jul 8, 2015 08:12 AM
