replacement wheel stud knurl diameter?
I have a 2003 silverado 5.3l RCSB and I need to replace several of the wheel studs on my rear as they have been snapped off by the previous owner. I believe that i need to get some 14mm X 1.5 studs but I see different knurl diameters and not sure which to get , they range 16.00mm +/- .25 or so ... any idea which ones fit factory ? are the larger diameter just a tighter fit vs the smaller diameter, but will both fit?
thanks
_zblee
thanks
_zblee
So napa had two stud sizes. they had one for the front and one for the rear, the front were the longer version and the rear being the shorter. I bought both and before installing either I measured the length of the existing ones and found the rear to be the shorter of the two. based on that I ended up installing the shorter version and it installed with ease .
mrgrim
Jul 8, 2015 08:12 AM
