rear end suggestions
Old Apr 14, 2010 | 07:59 PM
Default rear end suggestions
Well I've had my truck for a couple years now and I'm thinking about changing the rear end out I want to actuly burn both tires instead of one lol I'm new to this so any tips will be helpful btw its 4x4 with towing package and my tires are kinda big to be doin some burnouts so thought i would just ask someone who knows what theyre talking about and see if the would recommend a good setup to get the power to the ground and still have the 4wheel drive if i need it
Old Apr 14, 2010 | 09:16 PM
cdub81's Avatar
eaton trutrac for 2 wheel wonder then as far as the power chunk the tb spacerget a cam lt's and some tranny work and a nice stall should leave a good footprintoh and if your on a budget just get a dyno tune and some 4 10's and that would get you "started"
Old Apr 14, 2010 | 10:23 PM
I am on a buget kind of my pockets aren't that deep I guess I should ask what's the best bang for your buck
Old Apr 14, 2010 | 11:15 PM
brent5631's Avatar
Stock g80 for cheap. But there is a reason that people get rid of them.
Old Apr 14, 2010 | 11:38 PM
Well I do want some peformance gains so I don't want to put in somthing stock that's just going to **** out on me and have to do it all over again I don't want to waste my time on that
Old Apr 18, 2010 | 04:48 AM
dhpro's Avatar
I got an Auburn Gear LSD and Richmond ring & Pinion...<$900 installed.
Old Apr 18, 2010 | 09:44 PM
fredkj3's Avatar
i have the auburn posi.. and so far so good.. i probable have 30,000 hard miles on it... think i got it new on ebay for like less than 350
Old Apr 18, 2010 | 09:55 PM
fredkj3's Avatar
http://cgi.ebay.com/ebaymotors/Aubur...item2eac687379
this will lock both tires for cheap.... HEHEHE
Old Apr 18, 2010 | 10:29 PM
Daryn's Avatar
Formerly darynC-10/23/10
ebay has detriot trutracs for 380 ish , rons machining service.
Old Apr 18, 2010 | 11:05 PM
1Bear's Avatar
If you actually use your truck in an enviroment where you need 4WD, I would suggest reading this thread to help you better narrow down your selection. https://www.performancetrucks.net/fo...d.php?t=456366
