Rear Detroit TT Install
Old Dec 31, 2006 | 01:49 PM
KySilverado's Avatar
Default Rear Detroit TT Install
Guys,
Within the next few weeks I am going to try and install my first set of gears and carrier. OEM 4.10's with a Detroit TrueTrac. I've bought a complete NOS front differential with 4.10's to cover the front end gear swap.
I am going to time it with a suspension drop. Lower control arms up front and hanger shackle change in the rear.
I am thinking that since this is my first install and since I'll be deep into the rear suspension that I will just pull the whole rearend and get it out from under the truck to help with the setup. Am I ? Should I just leave it in the truck and do it there? I don't have a lift. Will be doing it on the garage floor.
Old Dec 31, 2006 | 05:14 PM
SlvrSierra4.8's Avatar
You might want to shoot AxisT6 a PM for any install tips and info. As he is the rearend guru around my area and really knows his stuff. With OEM (AAM) 4.10's the backlash is very tight (3-6 thousandths) and will be much harder to install than a quality aftermarket gear such as Yukon. Just something to consider since this is you first install.
Old Dec 31, 2006 | 05:26 PM
Derek @ EDO's Avatar
FormerVendor
get you some good tall jackstands! No need to take out the whole rear end!
Start early, this may take a long time if you fall into problems
Old Dec 31, 2006 | 06:36 PM
TURBHOE's Avatar
i did both my detroit installs with truck on jack stands and rearend in place. i recomend removeing the sparetire and tire hanger. because it will **** you off when you nail your head on it. lol
Old Dec 31, 2006 | 06:45 PM
wkdivr's Avatar
Think about your driveshaft balance, and maybe a safety loop. That's what I'm going to do. The factory balance on the truck shaft leaves alot on the table. I'm going to go with either a chrome-moly, or aluminum shaft with 1350 universals, and a highspeed balance. I bought a loop today at Summit, just have to modify it to fit on my truck. The driveline on our trucks is pretty good, already, but with a good driveshaft with 1350 universals, it should never give you problems. If you decide to go that way, look into getting a pinion yoke for 1350's while you have everything apart. Maybe some c-clip eliminators, too. Man.........it just keeps going on, and on! IT NEVER ENDS!!!!
Old Dec 31, 2006 | 07:20 PM
Looks like another dive under the truck.
Thanks for the tip... I'll drop the spare. Need to anyway. Its never been out from under it.
Old Dec 31, 2006 | 07:22 PM
You are right. Never ends. I am going to at least a good drive shaft sometime. Already looking. Meantime I do need a balance check. Can't find anybody that does it in the area. Central KY you know. Just got indoor plumbing couple years ago.
Old Dec 31, 2006 | 08:30 PM
TURBHOE's Avatar
the hanger only has like one bolt holding it on too. i leaned back and smacked my head on it. it came out quickly after that.
thunder550
Oct 8, 2015 04:53 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Dezert1500
Jul 30, 2015 02:51 PM
Ketis
Jul 23, 2015 12:37 PM
