radix+rwd+4.10 GEARS!!!
Old Apr 5, 2010 | 02:39 PM
blackbeast ss's Avatar
Default radix+rwd+4.10 GEARS!!!
i have a 2006 sss with 3.73 right now and thinking of installing some 4.10s to get me a little higher in rpm when im in 3rd gear crossing the traps.my best et was 12.5 @ 108 with lots of wheel hop!!but i will be fixing this too....I know that traction will be a little harder but i seen trucks and tbss rwd with 4.10s that hook with NO problem, and have way more power than i do....
is anybody currently running 4.10 rwd with a maggie?? is it worth it ????
give me some reviews on your likes and dislikes??
THANKS IN ADVANCE
Old Apr 5, 2010 | 04:17 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Id fix your traction issues first and just add more power, the swap from 3.73 to 4.10 especially in an extended cab is no where near one of the first mods Id do. More like the last...
Old Apr 5, 2010 | 04:18 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
What size tire are you running, that might be an easier fix for the track.
Old Apr 5, 2010 | 05:00 PM
im running m&h racemasters 325/45/17 @ the track
caddy03pimpin's Avatar
He is running 28" M&H tires
Old Apr 5, 2010 | 05:02 PM
trever1t's Avatar
I run 30.5" tires, 3.73 rear.... 28" would be about perfect for me I cross the traps ~5200 IIRC
Old Apr 5, 2010 | 06:05 PM
what are your mods bro thats a good 1/4 mile
Old Apr 5, 2010 | 06:10 PM
trever1t's Avatar
click my sig....thanks
Old Apr 5, 2010 | 09:29 PM
so my best bet would be staying with the 3.73s?
Old Apr 5, 2010 | 10:35 PM
cheyenne383's Avatar
TOWN CRIER
Yes, work on other areas first and worry about gears later. If you have $500-1000 to spend on something there's a lot better things then gears for results, traction being #1.
