Quick clutch line replacement question
Old Nov 12, 2011 | 03:17 PM
TURBHOE's Avatar
Default Quick clutch line replacement question
I've got the earl clutch fittings and a -4 line. Can I get to the slave cyl side to take out the stock quick connect or does the Trans have to come off?
Thanks. Also how do I bleed it? Or do I just have to let fluid run through the hose while I connect it?
Old Nov 13, 2011 | 09:21 AM
Vince B's Avatar
It might help us here if we knew what you were working on! How about some pic's?
Old Nov 13, 2011 | 12:04 PM
TURBHOE's Avatar
oops my bust. its a 2001 silverdao with a 4.3 and nv3500. i think we decided to just do it when we replaced the throw out bearing. its really really noisy.
Old Nov 13, 2011 | 12:31 PM
Vince B's Avatar
Thanks for the added info. It might help someone give you better knowing what you have. There should be a bleeder screw at the slave. Normally you would bleed it just like you would brakes. However it seems like some of these systems can be kind of picky at times. I have seen a few different systems for bleeding the clutch system but I'm not really familiar with them. Hopefully someone will chime in before you attack the throwout bearing!
Old Nov 20, 2011 | 08:39 AM
TURBHOE's Avatar
Well, we through in a new throw out bearing and the clutch line fittings and a new line. We cracked the bleeder and used a whole bottle worth of fluid and still no clutch. So wtf? What am I missing? Any tips to bleed this damn thing?
USMCvet0311
Aug 1, 2015 07:45 AM
76k10chase
Jul 17, 2015 01:48 PM
bsn1989
Jul 16, 2015 08:20 AM
1320Chicken
Jul 14, 2015 10:58 PM
