Question on changing 2-4 band in 4l60e
Sorry ive been busy with work latley. But i found a website that has a breakdown with gm part numbers. I will be replacing the reverse input drum buying a wide band, and also going through the rest of the trans. My question now is, is there a a better reverse input clutch pack i can buy or is stock fine. I assume the reverse input clutches dont see much wear.
Now are the stock GM frictions Borg warner? I can get stock OE clutch packs cheap. I will be using 8 .067" Borg Warner Hi-Energy Frictions and 7 .095" Steels for the 3-4 Clutch pack and a wide carbon band. The Sonnax Hi-Tech Input Housing did come with a billet Overrun piston to fit over the reinforcement sleeve. So yes just forward and 3-4 piston.
and again thank you for your replys.
Yes oem are BW .80..the .67 came out in the 4l65/70..for the sonnax drum id try and fit 8 full thickness .80 borgwarners..6 kolene .80s and 1 .94 gave me good clearance think around .30 if i remember correctly
slowlsx
Aug 13, 2015 08:28 PM
