Proper Break In-FLT 4L65E Level 5?
Old Aug 29, 2007 | 07:12 PM
SpdFrk's Avatar
Default Proper Break In-FLT 4L65E Level 5?
Hey Guys, I just got my level 5 FLT today and was curious how other Level 5 users broke in your trannys. i plan on drag racing this weekend. Should i or should i wait?
Thanks for any info
Old Aug 29, 2007 | 07:20 PM
nightrunner's Avatar
Mr. Obvious
i think vince@FLT once said for white1 to do a 4wheel burnout out of his driveway for the break-in procedure. anyone care to validate this??
yes its safe to race with this weekend
Old Aug 29, 2007 | 07:27 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
They do dyno every transmission before shiiping. I ran mine around lightly for a few weeks...........
pysch! I think you'll be fine but why not ask the guys at FLT?
ZR1 DREAMING's Avatar
They have an in-house trans dyno that takes care of all the break-in you'd need to do.
Stick it in there and roll brother!
Old Aug 29, 2007 | 07:42 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Consider that validated.
If I know Matt, the FLT L5 has had the snot beat outta it since the first engagement of forward gears.
Old Aug 29, 2007 | 10:45 PM
SpdFrk's Avatar
thanks for the info guys-it is basically what i had planned on doing. i figure the 45 mile drive to the strip is enough break in.
Old Aug 30, 2007 | 07:00 AM
ZZebes's Avatar
vinces exact instruction
Put it in
Start it up
warm to operating temperature
Break in done
Old Aug 30, 2007 | 08:10 AM
FLT's Avatar
FLT
FormerVendor
As all coments above that is how most of you guy's do it. If you are running a fresh converter it is best to cycle the lock up 20-30 times. Ignore if your converter was tested here at FLT. Do this by some normal driving around town. I do recomend that you make sure to run it through the gears a few times and make sure it is full before driving with the wheels in the air. Basically make sure all is good with no leaks and everything functioning correctly. Take it for a testdrive if all is well without a problem or leaks, then as mentioned and photo'd above enjoy the ride. Vince
Old Aug 30, 2007 | 08:15 AM
ZZebes's Avatar
Glad i could help vince
SS94S10
Jan 3, 2019 01:57 PM
Avalanche2002
Nov 30, 2015 07:31 AM
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
Wolftrk99
Oct 2, 2015 08:17 AM
