Pinion angle...and i have used the search button!
Old Apr 13, 2009 | 10:24 PM
2005 Silverado's Avatar
SPAM HUNTER
Default Pinion angle...and i have used the search button!
What are you guys running for a pinion angle.
Dustin
Old Apr 13, 2009 | 10:29 PM
SincalT/A's Avatar
With your setup bout 2*or3* negative.
It also depends if you plan on any type of traction bars.
Slicks/Street tires?
Nitrous?
Lowering?
Old Apr 13, 2009 | 10:35 PM
SPAM HUNTER
Just to verify i have it right, is it driveshaft angle minus pinion, or vise versa. Or should i get a protractor, and tape a pencil to the driveshaft.
Dustin
Old Apr 13, 2009 | 10:39 PM
SincalT/A's Avatar
It is flat surface of the yoke to the flat ground your truck drives on.Meaning at 0* you yoke is parallel with the road.
Old Apr 13, 2009 | 10:46 PM
Mangled03gmc's Avatar
Baltimore Whore
What drop are you running on the truck peckerwood???
Old Apr 13, 2009 | 10:54 PM
SincalT/A's Avatar
I need to clear this up cause I am a retard.
The flat surface of the yoke would be 90* to the ground while the splines would be parallel.
Old Apr 13, 2009 | 11:13 PM
SPAM HUNTER
2 inch drop shackles...dingle berry
Ok just ordered an angle finder, i will see how far from -3ish i am
Dustin
Old Apr 14, 2009 | 12:01 AM
dlt76028's Avatar
Dustin
if your shackle only you might need to shim the rearend down. raising the back end of the leafs make the differential point up.
Old Apr 14, 2009 | 12:11 AM
SPAM HUNTER
Tomorrow i am going to install the stock shackles back on. If the vibration goes away i will take the pinion angle measurement then i will have some numbers to try to achieve.
Dustin
Old Apr 14, 2009 | 12:44 AM
lucky77's Avatar
Banned
you need 1 of these . magnetic one . . you placed it on th yoke . make sure your truck is parked on a straight* your angle should be - 2 or close. .. like -3 or -1 . .so when u floor it it's at a perfect angle 0 . . you could also place the angle on the driveshaft where its parallel . . . i'll post some pics later on so u can have an Idea' if ur angle is positive , you need Shims' .
